![]() | Home > Technical (L322) > daytime LED running lights |
andrewcooke1720 Member Since: 14 Feb 2011 Location: Co Kerry Posts: 28 ![]() ![]() ![]() |
where is the best place to pick up the positive feed to the daytime lights when the engine is turned on and running, the alternator? have found two skinny wires that go to 12V with the key turned but don't want to hack in and blow an ecu ...... Any suggestions or other locations i should consider? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
http://www.fullfatrr.com/forum/topic11078.html ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
And here:
problem solved on eBay, switch purchased that operates when the battery voltage exceeds 13V and turns the lights on and switches them off when the side lights are switched on. happy days. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
I bought one of the voltage sensing DRL relays off the bay and it dont work |
That's a nice little addition with the voltage checker. |
you forgot to mention all the Chav bling Joe that takes a lot of power too |
