Home > Maintenance & Mods (L322) > mantec front sump guard 8mm plate
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Will they be allie, or dural, like rally car sump gaurds?
Post #12811 9th Feb 2010 9:09pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
just 8mm alloy sheet folded to spec and welded as required c/w posibly galv brackets and mountings Thumbs Up
these are the winch kits ready for any lowline winch Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
front sump guard for pre faclift
tank guard all models
exhaust guard all models (not sure on s/c)
very poor pics but an idea Thumbs Up
if you look here these are real pics as fitted to my car
http://www.fullfatrr.com/forum/topic366.html
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  onto no6 Range Rover
Everyone needs a hobby
Post #12813 9th Feb 2010 9:14pm
SteveMFr
Site Sponsor
Interested! Do you know if the spoiler on the post facelift models is the same? Will the guard fit? How much for the winch kit and a 3 guards?
Will be on your side of the channel in 6 to 10 wks depending on the project I'm working on. Could be a good opportunity to save on shipping as I was considering driving over anyway.
Another question: what would happen if you put a jack under the very tip of the sump guard at the outside edge? If the car dropped 3" or 4" on to the tip? Is it that solid?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #12826 9th Feb 2010 10:58pm
speedymarktd6
the guards ive got will only fit the pre facelift , the one fitted to my own i fab'd mostly myself from a damaged g4 guard
the winch cradle kit complete minus the winch will be about £400 give or take no vat to pay eigher
as for strength of sump guard its supported by four m10 size bolts that attatch solidly to the front tube sub section that holds all the suspension and engine components they are only structurally solid if jacked up under the load bearing parts it attaches to as you would get flax if jacked up in the middle of the plate and also the same with the genuine mantec part
if you was to drop down onto a ledge or boulder i would be confident that it will offer considerably more protection than the std plastic underguard
it is copied from the g4 vehicles so its good enough for whatever they were tested for Thumbs Up onto no6 Range Rover
Post #12832 10th Feb 2010 12:29am
SteveMFr
Site Sponsor
Mark, you say they're alloy are they aluminum? I'm also still interested in knowing where the pics of the facelift model come from.
Your winch kit looks the same as from these people:
http://www.extreme4x4ltd.co.uk/acatalog/RA...OUNTS.html
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #12897 10th Feb 2010 5:59pm
speedymarktd6
yes aluminium alloy and which facelift pics do you mean the ones in my link on the bucks blue facelift is my own and ithe sump guard is a much modded item as for the facelift at the start of this thread the american one thats fitted with a mantec guard thats available from them
as for the winch yes they are the same pics mine is a library pic but as for the kit they are all copy's of the oem L/R item and theres is a very good price bearing in mind the colosel fabrication work involved thats a supurb price Thumbs Up onto no6 Range Rover
Post #12903 10th Feb 2010 7:33pm
SteveMFr
Site Sponsor
Yes I understood that - I was just wondering which forum/whatever those pics were in. Thanks.
It does seem to be a good price for that kit - then again, I read somewhere that extreme4x4 is the reincarnation of another, now defunct co (Scorpion Racing?) and likely none too reliable....
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #12939 10th Feb 2010 9:47pm
Non Digital
Hungary
Re: mantec front sump guard 8mm plate
Hi There!
The MANTEC SUMP GUARD looking good. Where can I buy it? Its Be on the market?
Post #561745 16th Jul 2020 9:38pm
