![]() | Home > Maintenance & Mods (L322) > TD6 Transmission fluid |
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Mine's got 119k on it and it shifts brilliantly. I'm still gonna drain and flush it, though!
Right, the more I look at this, the more I'm convinced that you really don't have to use Texamatic. Total's ATF33 is broadly similar:
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Good work, misteralz, when it comes down to it, it is your car, us none tribilogists will no doubt continue to follow the herd |
Thanks! I'm following the herd because I could find Texamatic for a reasonable price. |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
Price today 20l Texaco ETL 7045E, Transmission Oil Texamatic 7045E
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Whatever oil you use remember to fit a quality filter or you will regret it!
Of course. I'm currently weighing up whether to drain, then refill, then flush with old filter in place, or drain, replace filter, refill then flush. Decisions, decisions... 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
vallef Member Since: 03 Apr 2012 Location: Stockholm Posts: 10 ![]() ![]() ![]() |
I have used Dexron VI (6) as GM the manufacturer in Strasbourg of the 5L40E announced that Dexron 6 can be used. As I live in Sweden I cannot get the original Texamatic, so if you can get it I would use it. I just had to be pragmatic. I did one flush, pan drop and transmission filter change at 118,000 km, old oil coming out was black. then after a 3km test drive I just did a drain. Then after 200km I did another pan drop, filter change and drain. Now I have been running on Dexron 6 for 6 months and 13,000km all through the Swedish winter where cold starts are at -25C also quite a few summer non-stop 400km trips. Everything is OK, box was good before the first fluid change but shifting is slightly better, quiter and smoother afterwards. I did this as preventative maintenance. Takes about 1 hour to do a pan drop and flush as I have done 3 now. Summary if you can do it, try for the original Texamatic if you can, but Dexron 6 seems to be OK. I used a MPM Dexron 6, but if you look at the BMW forums they use the Mobil 1 Dexron 6 in the 5L40E transmission.
