![]() | Home > Maintenance & Mods (L322) > track control arm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
it appears i need to replace either the bushes or the whole track control arms.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Do you mean track control arm (steering) or toe control arm, stan ? (Don't have part number info to hand).
a few names for this part but its the 'tie rod' or 'track control arm' or 'front suspension arm'
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
As above, you will need a press to remove and then fit the bushes.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Buy complete arm, less faffing about |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1504 ![]() ![]() |
Agreed, buy a complete arm. V8 or else ... |
cheers chaps.. |
btw, will the wheel alignment need doing after wards? ... - .- -.
Did you mean this one:
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Replaced this arm on my FFRR a few weeks ago, the nuts were extremely tight but once these were loose the whole job took 30 mins. You can just see the arm in the photo below. It didn't cure the knocking noise though, it turned out to be track rod ends even though I could find no play in them. I've taken photo's of the job & I'll post it as soon as I get a chance.
Known in the manual as a tie rod:
Known in the LR WSM as the compression link
joe, it looks like the one that john has pointed out, the bar that has a twist in it .
A picture paints a thousand words |
