Home > Maintenance & Mods (L322) > track control arm
track control arm
it appears i need to replace either the bushes or the whole track control arms.
so if anyone has done this job , how difficult is it to just replace the bush rather than the whole arm.
part numbers to help are, RBX000200 for the bush and RBJ000120/RBJ000130 [right and left hand] ... - .- -.
Post #128357 29th Jun 2012 1:12pm
Do you mean track control arm (steering) or toe control arm, stan ? (Don't have part number info to hand).
Think most have suggested it is easier in the long run to replace the whole arm, unless you have the right tool to extract te bush .
Post #128391 29th Jun 2012 3:42pm
a few names for this part but its the 'tie rod' or 'track control arm' or 'front suspension arm'
i think maybe you might be right in respect of replacing the whole arm rather than just the bush..from reading on here , bushes can be Censored to get out... ... - .- -.
Post #128417 29th Jun 2012 5:45pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
As above, you will need a press to remove and then fit the bushes.
Best to buy the arms complete Thumbs Up
Post #128447 29th Jun 2012 6:34pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Buy complete arm, less faffing about Smile
Post #128448 29th Jun 2012 6:40pm
fisha
Agreed, buy a complete arm. V8 or else ...
Post #128464 29th Jun 2012 8:06pm
cheers chaps.. Thumbs Up ... - .- -.
Post #128490 29th Jun 2012 10:18pm
btw, will the wheel alignment need doing after wards? ... - .- -.
Post #128491 29th Jun 2012 10:31pm
Did you mean this one:
Front Lower Arm
or this one:
Rear Toe Control Arm
or something else ? .
Post #128492 29th Jun 2012 10:39pm
It's the top picture Joe but the rear arm number 7 in the image
Stan, easy enough job and you would be as well changing the bottom balljoints while you are at it
Post #128498 29th Jun 2012 11:17pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
Replaced this arm on my FFRR a few weeks ago, the nuts were extremely tight but once these were loose the whole job took 30 mins. You can just see the arm in the photo below. It didn't cure the knocking noise though, it turned out to be track rod ends even though I could find no play in them. I've taken photo's of the job & I'll post it as soon as I get a chance.
Robert.
Ps: the tracking is not affected by the replacement of the arm you describe Stan, so no traacking required..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #128506 29th Jun 2012 11:31pm
Known in the manual as a tie rod:
Has it got an eccentric bolt on the inner end, and/or in the lower arm ? .
Post #128507 30th Jun 2012 12:06am
Known in the LR WSM as the compression link
No eccentric bolt...
Post #128508 30th Jun 2012 12:33am
joe, it looks like the one that john has pointed out, the bar that has a twist in it .
john, bottom ball joints? is it a big/expensive job?
ambulancekid,thanks for info
so consensuses is to still replace the arm rather than the bushes. ... - .- -.
Post #128517 30th Jun 2012 9:12am
A picture paints a thousand words Twisted Evil .
Post #128522 30th Jun 2012 9:25am
