![]() | Home > Technical (L322) > Is this normal suspension behaviour? |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Meer, so the compressor kits your selling arn't something ou have had made, but original Wabco compressors you got cheap without motors? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
@47p2. It's a german phrase ( as wel as a film apparently) which equates to don't let the b@stards get you down. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
I thought it was Geordie. |
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
@Rob2529: YES SIR...., original and new! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
| RenoHuskerDu Member Since: 27 Jun 2012 Location: Alsace Posts: 31
Sorry to hijack this thread, but I do have a similar yet worse issue with the Td6 I have on long-term test drive (eval for purchase):
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
Airbag or pipework leaks in that area, plus now an over-worked compressor. Put into off road height, then go and manually lift the car on that corner at the wing - any hissing? .
Yes in fact I just did a little gravel tamping. I set it up to full height, then heard hissing at the LF, after which the front went down an inch. My son was standing on the right side and he thought that the hissing came from the RF. Reno, on assignment in France. |
