![]() | Home > In Car Electronics (L322) > 04 Vogue no Audio. |
Saltyfish Member Since: 19 Jun 2012 Location: Yate/Bristol Posts: 22 ![]() ![]() ![]() |
i am a new L322 owner,i noticed my audio was only from the front door speakers so i decided to investigate. I removed the plugs from the DSP to find 2 pins in the smallest black socket were broke,i reconected after repairing the pins but still no sound or the DSP option on the screen (it was there before).
STEVE57 Member Since: 27 Apr 2012 Location: solihull Posts: 103 ![]() ![]() ![]() |
HI
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
The power amps for the hi-fi are in the BM54 radio module. Most of the docs refer to the DSP and an amp, but I don't believe that to be technically true. It is just a sound processor, dealing with line level signals.
OK so i had the BM54 unit repaired and still no sound or DSP option,ive checked and cleaned all connections. Is there any way off bypassing the DSP so i can hace sound???
knube1 Member Since: 28 Jun 2012 Location: mansfield Posts: 5 ![]() ![]() ![]() |
Just had a similar problem, everything operated correctly but no DSP on the menu, strip out DSP unit and the bottom terminals were covered in white powder, tried cleaning but still no audio, replaced DSP £299.00 for new unit then had it coded and all is back to normal. |
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
I had a similar problem, replaced dsp and bm54 still no sound. Took it to local dealership they tried reseting it and it worked. Although it took a few goes at reseting it for it to work. They checked wiring etc etc. the original dsp also had water damage.
