Home > Technical (L322) > Bad Wobble! Update
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Bad Wobble! Update
Ive got a bad wobble on my steering wheel under heavy braking. Light braking is fine just heavy braking at speeds on the motorway
I've changed the discs and pads approx 500 miles ago as I had this issue thinking it would resolve it but it's reappeared so I not think its the pads or discs
Any ideas where to start. It only wobbles under heavy braking and no other time
It's a 2004 4.4v8
Thanks
Neil
Post #128999 2nd Jul 2012 6:59pm
verydisco
Could it be your wheel bearings starting to let go? Have they been replaced in the Rangie's life? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #129000 2nd Jul 2012 7:03pm
cliffy
Pass, I'm not aware of them being done, it's done 62000
Post #129003 2nd Jul 2012 7:07pm
could be the servotronic valve which cant keep up with the braking.. ... - .- -.
Post #129040 2nd Jul 2012 9:03pm
cliffy
Am I best off putting it into land rover and biteing my nails?
Post #129057 2nd Jul 2012 9:52pm
Does it happen when the jetski isn't on the back ? Wink
If its not the servotronic valve it'll be something down under at the front. Still steering straight? If not maybe {tie rod / compression link / steering control arm } - it has many names Wink or the lower arm, or the track rod ends. Sounds like it all needs a wiggle. .
Post #129068 2nd Jul 2012 10:31pm
cliffy
Solved it, brake caliper was mullered and sticking, refurbed one and she is all good again
Post #135796 13th Aug 2012 11:09pm
