![]() | Home > Technical (L322) > tdv8 metallic whine |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Did anyone have any thoughts on this?
allisong Member Since: 28 Jun 2011 Location: UK Posts: 9 ![]() ![]() ![]() |
Most of those issues can be easily fixed by loading updated calibration software (via IDS) for the TCM and ECM (transmission control module and engine control module).
Allisong,
The 'groan' at those revs, are you 100% you are not confusing the V8 exhaust note for a problem? Land Rover Addict
Possibly loose heatshield? I'm not sure if there any - but that would be roughly where they are (if they exist!). The only other thing that groans is the FBH (this will cut in at temps below 16 I think), and is there to assist in bringing the coolant up to temperature (and providing a means to heat the cabin!).
Definitely not the FBH. I know that groaning. This is different. More of a drone than a groan (if that is not too subjective!). And, as you say, the FBH noise goes away when everything is up to temp.
Does it occur under load, i.e. if you rev up to 2.245k rpm in the driveway, does it still happen? Land Rover Addict
No. Only under medium or high throttle input when transmission is engaged. I.e. drivetrain under load. -----------------------------------------------
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35794 ![]() ![]() |
i think you might have answered your question there...it does sound [no pun] like something to do with the drivetrain.. ... - .- -.
If it was my old D1 .. I'd suggest checking the UJ's |
Indeed. But which part is the question. And what to do about it!
get a couple of garages to take it on a test drive and get some quotes... ... - .- -.
I think you are probably right Stan. I am just nervous of spending fortunes on incorrect diagnosis and consequent unnecessary work! -----------------------------------------------
