![]() | Home > Technical (L322) > 'Water in fuel' warning light.... |
| Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202
Hey - so pretty hefty rainfall around where we live today. Lots of flooding and big puddles around the lovely(!) Grantham area.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
^^^^you would hope so, getting water in the fuel in a car is quite tricky nowadays, I get the problem often with my plant as the lads are not too hot at filling them from jerry cans without a bit od h2o getting in as well.
| Rolo Member Since: 11 May 2011 Location: UK Posts: 852
Wading depth is supposed to be 700mm, so you might want to ask Mrs Tom how deep that puddle really was as 47p2 says, probably just a short. If you had water in the fuel system, I'm sure you would have noticed by now. The engine would not like that one bit and start to cough. |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Maybe 'your lads' are topping up Mrs Tom's FFRR |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Maybe check for water in the filter anyway. My mother got stuck one day because the petrol station attendant didn't close the tank properly and on her car that meant rainwater going straight into the tank (petrol). My dad spent hours draining the water out (he didn't want to take the tank out so first drained it and then used a cloth to dry it). Who knows maybe something similar happened to your car as well.............. MY 2010 5.0 SC Galway green and sand interior!!
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Worth mentioning the top tip if there is a little water in the fuel - pour a couple of litres of meths (methylated spirits) into the fuel tank. The meths will absorb the water and happily pass through the injectors and burn. I've done this is the past on diesel and petrol engines (useful on narrowboats) and it always seems to do the trick. |
Simes is right, that works a treat. Also using biodiesel in larger amounts dries the fuel system out. MY 2010 5.0 SC Galway green and sand interior!!
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
If a couple of litres of petrol miss fuelled in to a common rail diesel can be extremely damaging what is meths going to do ?
| Autobiography Member Since: 10 May 2011 Location: UK Posts: 926
It's wet round near me and got the same message today. Pressed 'ok to clear' and it went off. Came back a few minutes later but now gone completely. Any cause for concern do we think? |
Also, love how the warning message says 'see handbook' but there is nothing in the handbook which says anything about 'water in fuel.' |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
If you have recently fuelled up it could also be that the filling station has got water into their tanks and you have fuelled rain water that has leaked into the station's fuel tanks................. This happened last year at our local Morrison's 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
| Allan Member Since: 15 Aug 2012 Location: Yorkshire Posts: 46
Same here on my 4.4 TDV8 a few months back.
| ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341
Please do not put Meths into your fuel tank. Any water whether mixed with meths or not running through a common rail diesel is asking for big trouble. Thats why they have a water trap and warning light so we do not run water through the motor. Most likely an electrical fault with your car.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Seems to be only latest 2011/12 cars....... |
