Home > Technical (L322) > 'Water in fuel' warning light.... |
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 |
Hey - so pretty hefty rainfall around where we live today. Lots of flooding and big puddles around the lovely(!) Grantham area.
6th Jul 2012 4:59pm |
^^^^you would hope so, getting water in the fuel in a car is quite tricky nowadays, I get the problem often with my plant as the lads are not too hot at filling them from jerry cans without a bit od h2o getting in as well.
6th Jul 2012 5:57pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
Wading depth is supposed to be 700mm, so you might want to ask Mrs Tom how deep that puddle really was as 47p2 says, probably just a short. If you had water in the fuel system, I'm sure you would have noticed by now. The engine would not like that one bit and start to cough. |
6th Jul 2012 7:11pm |
Maybe 'your lads' are topping up Mrs Tom's FFRR |
6th Jul 2012 9:37pm |
Maybe check for water in the filter anyway. My mother got stuck one day because the petrol station attendant didn't close the tank properly and on her car that meant rainwater going straight into the tank (petrol). My dad spent hours draining the water out (he didn't want to take the tank out so first drained it and then used a cloth to dry it). Who knows maybe something similar happened to your car as well.............. MY 2010 5.0 SC Galway green and sand interior!!
6th Jul 2012 10:54pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Worth mentioning the top tip if there is a little water in the fuel - pour a couple of litres of meths (methylated spirits) into the fuel tank. The meths will absorb the water and happily pass through the injectors and burn. I've done this is the past on diesel and petrol engines (useful on narrowboats) and it always seems to do the trick. |
10th Jul 2012 3:03pm |
Simes is right, that works a treat. Also using biodiesel in larger amounts dries the fuel system out. MY 2010 5.0 SC Galway green and sand interior!!
10th Jul 2012 4:03pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
If a couple of litres of petrol miss fuelled in to a common rail diesel can be extremely damaging what is meths going to do ?
10th Jul 2012 4:22pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 918 |
It's wet round near me and got the same message today. Pressed 'ok to clear' and it went off. Came back a few minutes later but now gone completely. Any cause for concern do we think? |
4th Nov 2012 10:30pm |
Also, love how the warning message says 'see handbook' but there is nothing in the handbook which says anything about 'water in fuel.' |
4th Nov 2012 10:35pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
If you have recently fuelled up it could also be that the filling station has got water into their tanks and you have fuelled rain water that has leaked into the station's fuel tanks................. This happened last year at our local Morrison's 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
4th Nov 2012 11:15pm |
Allan Member Since: 15 Aug 2012 Location: Yorkshire Posts: 46 |
Same here on my 4.4 TDV8 a few months back.
5th Nov 2012 2:10am |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Please do not put Meths into your fuel tank. Any water whether mixed with meths or not running through a common rail diesel is asking for big trouble. Thats why they have a water trap and warning light so we do not run water through the motor. Most likely an electrical fault with your car.
6th Nov 2012 7:05am |
Seems to be only latest 2011/12 cars....... |
6th Nov 2012 8:31am |
