Home > Technical (L322) > Sitting in D whilst stationary
Page 3 of 4 <1234>
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Never played with the selector on any of my many auto's - unless parking up. Putting it into park scares the person behind as you go through R .... both ways! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #130817 13th Jul 2012 9:20am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I've driven HGV,PCV and cars with AUTO, and it's never been mentioned or required during test to put vehicle in neutral if stopped for short periods.
Although, some large vehicles when the handbrake is applied disengage drive themselves, and as soon as handbrake is released engage drive by themselves automatically.
Post #130821 13th Jul 2012 9:31am
T24RES
I was under the impression that if you slide the selector through R to P without pausing the reversing lights would not activate. Similarly you don't get a flash of the reverse camera on the screen.
Might be talking out of my bits, its not unheard of Whistle
Post #130835 13th Jul 2012 10:40am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I tend to either slip it into Neutral or Park. Annoyingly, the rotary controller is poor for this (why won't pulling both paddles select neutral?).
I try not to sit with my foot on the brakes. High intensity LED brake lights boring into the eyes of the person behind is poor form, imho.
Post #130852 13th Jul 2012 11:15am
DMRR
I thought the 8 speed disengaged at idle anyway? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #130857 13th Jul 2012 11:28am
Emperor Mong
Doesn't feel like it.
Post #130994 13th Jul 2012 10:17pm
DMRR
Pretty sure I got told in no uncertain terms it does, and that's why it's better than the supercharged gearbox..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #130995 13th Jul 2012 10:20pm
RRPhil
“Transmission Idle Control disengages 70 percent of the drive when the vehicle is stationary and the engine is idling in Drive, significantly reducing consumption in the urban cycle”.
http://newsroom.jaguarlandrover.com/en-in/...ss_010411/
Phil
Post #131006 14th Jul 2012 12:26am
Andy
I used to work on Fork lift trucks and HGVs for 18 years prior to joining the police.
My experience of auto boxes, is that when you apply the brakes, it cuts the drive. Having said that, I agree that when you are the lights in a FFRR, it feels like it still wants to go. This puzzled me at first, as I'd not experienced this before on the vehicles I'd worked on. I'd never owned an auto prior to the FFRR either, so I was never sure whether it was "right".
I've started putting mine in neutral for long periods of standstill. With the 20" rims causing additional vibration, it's more comfortable as well. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #131041 14th Jul 2012 12:20pm
I've had lots of automatic cars and only the FFRR feel like it's wanting to go when left in gear at traffic lights
Post #131047 14th Jul 2012 12:36pm
ebajema
I have noticed the "wanting to go" feeling with a lot of "big engine" automatics to be honest. The more modern cars are now getting clutch disengage options though. MY 2010 5.0 SC Galway green and sand interior!!
Post #131052 14th Jul 2012 12:46pm
I've driven Jags, Mercs, Audis, Rolls Royces, Daimlers, Bentleys and never felt them trying to move forward when in gear
Post #131056 14th Jul 2012 1:27pm
simon1233
My experience with autos (based on BMW 525i touring auto, merc e270CDI estate, RRS & now TDV8 FFRR) is that they all naturally 'creep' as the fluid is in constant circulation in the torque convertor. Normally there is not sufficient power to overcome a small gradient say, but on the flat or facing downhill the car would naturally move.
Also, I just hold the car on the brakes at the lights. If I am in a traffic jam and will be stationary for a long time then I will go into N or P and use the handbrake (but mainly so I can watch tv Rolling with laughter )
Simon
Post #131097 14th Jul 2012 8:23pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Almost all of the cars I have had in the past 25 years of driving have been, "autos" but I have no experience of post 04 cars. ALL my pre 04 cars I had crept in D so I always felt it was more efficient to slip it into P when stationary. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #131099 14th Jul 2012 8:56pm
sleepezy
I used to generally move into n when stationary so I didn't have to sit on the brakes and the rpm was lower (so presumably using less fuel)
However, my recent gearbox woes were diagnosed (correctly from this forum) on wear in the gearbox lever pivot thingy - presumably only made worse by moving it more... As a result I now leave in gear and apply the handbrake (which no doubt will also experience wear too...)
Post #131119 14th Jul 2012 10:12pm
Page 3 of 4 <1234>
