![]() | Home > Maintenance & Mods (L322) > rangie does not want to start |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
You could ask Duckworth Dan to Fedex/UPS a new pump to you ?? MY 2010 5.0 SC Galway green and sand interior!!
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
How much petrol is in the tank - if 1/4 full or less - could be the problem? - but pump will still need changing .
To be sure, maybe open up the tank and see if there is anything clogging the filter. Maybe dirt build up over time has clogged it up. Also replace your fuel filter, I believe that type still has an external fuel filter.
Also, again to be sure, check all your electrical connections, fuses related to the fuel injection/ignition. A connector that is a bit loose, maybe hoses in the vacuum system etc. could have big effects all of a sudden. And since it is an older car in a warm climate, the hoses could be getting "bad" by now. MY 2010 5.0 SC Galway green and sand interior!!
| vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390
@joe90 - drove only 90kms after filling it up.
Are you sure they put petrol in it and not diesel ?? MY 2010 5.0 SC Galway green and sand interior!!
an update re my car that did not want to start. after replacing the fuel pump she is up and running again |
Good to hear it is resolved. MY 2010 5.0 SC Galway green and sand interior!!
| All times are GMT |
