![]() | Home > For Sale & Wanted > Wanted Front Fog Lamps |
That looks like them Joe |
You could always remove the silvering and spray them with chrome paint.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
You are not alone John, mine are just like that too, but having adapted them to DRL's with LEDs in it doesn't matter quite so much. I too thought about lining with some bacofoil or similar to improve reflection.
The lens is plastic Joe, so in theory it should be possible to wet sand and compound back to almost original condition.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Air conditioning alloy tape |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
+1 for ali tape thats what i did mine up with, not quite good as new but ok and much better than the mess they were. You can work it into shape without to many creases and polish it after Mine was a blue one! |
So where does obtain obtain AC alloy tape from? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
screwfix?
The AC alloy tape shop duh! Craig ![]() |
Sorry! Of course i meant...
Thanks Craig |
They do lots of sizes, this will give you a better view... http://www.screwfix.com/p/no-nonsense-alum...-45m/46950 Good luck, let me know how you get on... Craig ![]() |
New fog lamps now fitted and looking much better |
I decided to try and renovate the old fog lamp and see what sort of results I could obtain, sadly not good enough but it does look better then having lots of corrosion.
