Home > For Sale & Wanted > Wanted Front Fog Lamps
Page 2 of 3 <123>
That looks like them Joe Thumbs Up
Lets see if Dan can beat that price Whistle
Post #131194 15th Jul 2012 1:28pm
The problem with my fog lamps is the silvering which seems to be suffering water ingress
Post #131197 15th Jul 2012 1:43pm
You could always remove the silvering and spray them with chrome paint.
Probably last as long as the original. Idea
Post #131198 15th Jul 2012 1:53pm
You are not alone John, mine are just like that too, but having adapted them to DRL's with LEDs in it doesn't matter quite so much. I too thought about lining with some bacofoil or similar to improve reflection.
You can see all the damage to silvering on mine
You can also see my glasses are quite pitted/frosted, wasn't sure if this was by age or design, yours look much clearer than mine.... .
Post #131204 15th Jul 2012 2:26pm
The lens is plastic Joe, so in theory it should be possible to wet sand and compound back to almost original condition.
Your reflectors look slightly worse than mine, it's my o/s that's the worst
Post #131205 15th Jul 2012 2:30pm
Air conditioning alloy tape Thumbs Up works very well on lights as its heat proof'ish
craig Thumbs Up
Post #131255 15th Jul 2012 7:47pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
+1 for ali tape thats what i did mine up with, not quite good as new but ok and much better than the mess they were. You can work it into shape without to many creases and polish it after Mine was a blue one! Smile
Post #131264 15th Jul 2012 9:19pm
So where does obtain obtain AC alloy tape from?
Post #131273 15th Jul 2012 10:12pm
screwfix?
dunno if this is the stuff.
http://www.screwfix.com/p/unibond-duct-tap...of-2/87990 ... - .- -.
Post #131275 15th Jul 2012 10:18pm
The AC alloy tape shop duh!
Craig Whistle
Post #131276 15th Jul 2012 10:18pm
Sorry! Of course i meant...
http://www.screwfix.com/p/corotherm-ariel-...tid=262564
Craig Thumbs Up
Post #131277 15th Jul 2012 10:21pm
Thanks Craig Thumbs Up
Post #131282 15th Jul 2012 10:32pm
They do lots of sizes, this will give you a better view...
http://www.screwfix.com/p/no-nonsense-alum...-45m/46950
Good luck, let me know how you get on...
Craig Thumbs Up
Post #131285 15th Jul 2012 10:36pm
New fog lamps now fitted and looking much better Mr. Green
Post #133591 30th Jul 2012 3:53pm
I decided to try and renovate the old fog lamp and see what sort of results I could obtain, sadly not good enough but it does look better then having lots of corrosion.
The reflector area is an awkward shape and I doubt very much if it would be possible to use the AC tape method mentioned earlier.
I removed the mirrored metal base from the housing and stripped off the silvering using a Dremel with wire brush attachment. I then rubbed out as many blemishes on the alloy as possible using grade 400 sand paper before rubbing over with 1200 wet and dry and 2000 wet and dry. I then spend ages trying to polish the alloy with cutting polish and the Dremel but it must be a cheap alloy as the results were poor.
Plan B and I purchased a rattle can of spray chrome, what a waste of money that was, I would have been better using aluminium paint or even silver paint (note to self to contact paint manufacturers and complain).
The results are not good but is has to be better than all the corrosion
This is the 'chrome' cap that is supplied with the rattle can which should give an indication of the contents.
I wonder what trading standards will have to say...
Post #134310 4th Aug 2012 12:00pm
Page 2 of 3 <123>
