Home > Technical (L322) > detachable towball wont lock in - now solved
m3mjw
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hopefully some wise one on here will have an answer for me. When i bought the car it had everything on it bar the actual detachable towball which i bought last week. This part is brand new and original westfalia just like the receiver. I can get it just about all the way in but it just wont lock in to place. Says on instruction it should just push in easily and lock but it seems to be getting wedged. I have it all correctly pretensioned etc. The receiver has not had the bung in and i am wondering if due to it getting wet etc whether part has contracted or something? I have managed to get it in with a bit of assistance with a hammer and then had to use a hammer to get it out again but that is not right. Any ideas?
thanks in advance
Marc L405 4.4 SDV8 Santorini/Black VSE
L332 4.4 tdv8 stornoway/Ivory VSE gone
L332 3.6 tdv8 black/sand vogue gone
Mk 7 vw golf r black/black(swmbo)
Mini Cooper s grey gone (swmbo)
BMW e60 m5 black/black gone
BMW e46 m3 silver/black gone
BMW e39 525i m sport blue/sand gone
Vw mk 4 golf gti blue/black gone
Post #131310 16th Jul 2012 8:49am
clean out the receiver, probably a bit of crap and rust up there.. ... - .- -.
Post #131312 16th Jul 2012 8:54am
m3mjw
cheers Stan i have had a look and it actually looks fairly clean and tidy and no obvious thing to block it. Might have a go with a small file around the inside? L405 4.4 SDV8 Santorini/Black VSE
Post #131314 16th Jul 2012 9:00am
at least you know it does work [with a hammer] so cleaning it with a file or emery cloth makes sense..spray some silicon lubricant up there as well maybe.. ... - .- -.
Post #131316 16th Jul 2012 9:06am
I know it's the bleeding obvious but you are pulling the locking wheel out and turning anti-clockwise aren't you ? 2008 MY Supercharged
Post #131317 16th Jul 2012 9:07am
m3mjw
cheers will give it a go Thumbs Up L405 4.4 SDV8 Santorini/Black VSE
Post #131318 16th Jul 2012 9:07am
m3mjw
yes and that locks in to pretension mode no issues there. As i say with assistance of hammer it does go that last little bit and lock but i know that is not right L405 4.4 SDV8 Santorini/Black VSE
Post #131319 16th Jul 2012 9:09am
it is the correct one for a fullfat?...just wondering whether RRS or d3/4 ones [if they have them] are different... ... - .- -.
Post #131321 16th Jul 2012 9:18am
If the receiver is the type that has a plastic cap on the top, prise the plastic cap off and pour some oil in.
Also prise off the cap on the towball part and pour oil in there.
These bits seem to corrode over time.
Post #131322 16th Jul 2012 9:44am
m3mjw
yess definite ff. the rrs/d3 ones are different L405 4.4 SDV8 Santorini/Black VSE
Post #131334 16th Jul 2012 10:54am
m3mjw
Yes it is. will give that a whirl too. thanks for info Thumbs Up L405 4.4 SDV8 Santorini/Black VSE
Post #131335 16th Jul 2012 10:54am
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
I had this on ours. The red bung was in the side pocket with the dechable towbar. Rolling Eyes
An hour lying underneath it in the rain armed with a small pick set, a half round file, some emery and a tin of WD-40 sorted it. A horrible job, but at least I now know it's located properly. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #131338 16th Jul 2012 11:26am
m3mjw
mod edit : no need to use the quote button to reply
good man thanks. Glad its not just me who cant seem to get it all the way in Surprised
cheers
Post #131340 16th Jul 2012 11:36am
m3mjw
Now solved. Got 1/2 round file inside receiver. Only needed the slightest rub down. Wd40 everything and works like a dream now. Thanks to all who responded Thumbs Up L405 4.4 SDV8 Santorini/Black VSE
Post #131464 16th Jul 2012 7:58pm
The lock gets stuck so easily. WD40 on a regular basis is the only way! Discovery 4 HSE
Post #131466 16th Jul 2012 8:03pm
