![]() | Home > General > Starting TDV8 when very cold; anyone have any experience? |
Do you set the pre-heater to come on 20 mins before you intend to start? |
inkiboo Member Since: 13 Nov 2009 Location: Aubonne Posts: 80 ![]() ![]() ![]() |
I didn't think the TDV8 had a pre-heater? If it does, I have no idea how to activate it! |
It has a pre-heater and a hand book |
Unless I read it wrong, it referenced a pre heater and a remote control and mentioned being fitted to certain models. I therefore assumed my model was not one of them. I may even go down to the car park now to check. |
The remote is optional, or the previous owner may have just lost it.
Interesting; will ask at my local dealer. I 100% don't have the options in Settings to set times for the heater to come on. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3794 ![]() ![]() |
If its a Vogue model upwards, you should have had the remote with the car.
I don't know how the menu is laid out on yours, but on mine it's called "aux ventilation" on the main page, but being petrol there is no heater. If the heater is there I think its called Aux Heating?
It's a 2007 TDV8. Weirdly, it only has issues when parked in the underground car park; if we leave it outside overnight it is fine starting. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
The Pre heater or auxiliary fuel burner has NO beneficial effect on cold starting. If you use the pre heater to warm the cabin, in very cold weather it is most likely going to drain the battery and prevent the car starting.
The pre heater circulates hot water around the engine block - how can this not be beneficial? FBH System The system consists of a FBH unit, a FBH fuel pump and a changeover valve. On vehicles with the remote operation feature, the system also includes a FBH receiver and a remote handset. Fuel for the FBH system is taken from the vehicle fuel tank, through a line attached to the fuel tank's fuel pump unit, and supplied via the FBH fuel pump to the FBH unit. In the FBH unit, the fuel delivered by the FBH fuel pump is burned and the resultant heat output is used to heat the engine coolant. The changeover valve isolates the heater coolant circuit from the engine coolant circuit ![]() |
This is what RAVE tells me:
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 793 ![]() ![]() ![]() |
RRUK is correct. The FBH in the TDV8 FFRR is a 'Cabin Pre-Heater'. It does NOT warm the engine I'm afraid. |
As above, Rave states "The changeover valve isolates the heater coolant circuit from the engine coolant" and "the resultant heat output is used to heat the engine coolant"
