![]() | Home > Technical (L322) > disabling TPMS |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2067 ![]() ![]() ![]() |
Alex
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
mine is currently flashing at me, it does seem exremely precious. Discovery 4 HSE
Sidney Member Since: 20 Jan 2010 Location: Herefordshire/Welsh border Posts: 47 ![]() ![]() ![]() |
Hope you dont mind me hijacking the thread briefly, I was about to start a new one then saw this. I want to change to 19"'s on my 55plate exterior facelift vogue. How do I know if tpms is fitted and if so, If I fitted a set of new landrover wheels would the sensors just work or would they need 'pairing' to the car? |
There is a button on the dash that looks like a flat tyre with an exclamation mark. Opposite the DSC button I believe, under the parking sensor button. ![]() |
And in response to OP I know is not the answer you are looking for buy you can buy replacement sensors, you have to make sure you get the correct frequency, but I "think" BMW ones (around £30) will work.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Sidney, as far as I am aware this only became available on the 07 MY onwards |
It's been optional fit since 2002. ![]() |
Dan, there you go learn something new every day |
I think you are right there. Isn't TPMS mandatory in the US now (maybe from 2007?) I suppose it's easier for LR just to install it as standard on every car now than mess about. I've been interested in retrofitting the system to mine, not impossible, but a little too expensive for me to seriously consider it. Fact of the day: There are two types of TPMS. 1. Wheel sensors with RF Senders and Receivers monitor the pressure of the air in the tyre and relay that to a TPMS ECU. 2. The ABS ECU calculates the rolling diameter of each wheel & tyre, a flat/low tyre will be smaller and have to turn more in comparison to fully inflated wheels. BMW uses both of above, but only 1. fitted to BMW X5/ Range Rover. The RR system liaises with the vehicle alarm and is constantly "active" it will sound the alarm if there is rapid deflation of any of the wheels (tyre being slashed). ![]() |
Look at the wheel valves, if they are boring rubber ones they are not TPMS, if they look like metal bolts with a hexagon base, they are TPMS. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Looks like its not on mine thankfully, makes changing the wheels easier! Thanks guys, sorry to Hijack. |
