Home > Technical (L322) > disabling TPMS
alexbartman
2007 Range Rover Vogue SE TDV8 Java Black
disabling TPMS
SO i changed my wheels to 19" versions which have no TPMS valves ont hem - and now I have the incredibly irritating flashing then solid warning light telling me there is a TPMS system fault,
Bearing in mind the system is the best part of useless even when it works, how do I disable this?? I pulled the fuse, but that didn;t seem to work, so I put it back....any ideas - it just doesnt seem worth the expense to buy new valves , take the tyres off and then refit......
anty help gratefully received - I just cant bear warning lights - they drive me mad when they tell me soemthign I know perfectly well!!!
thanks
Alex
Post #13098 12th Feb 2010 10:04pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Alex
Same problem here.
My local dealer said it carn't be done Big Cry
They then went and bust the only 1 left, on the spare Censored idiots
Post #13101 12th Feb 2010 10:36pm
mine is currently flashing at me, it does seem exremely precious. Discovery 4 HSE
1993 90 Tdi
Post #13105 12th Feb 2010 11:08pm
Sidney
Wales 2005 Range Rover Vogue Td6 Cairns Blue
Hope you dont mind me hijacking the thread briefly, I was about to start a new one then saw this. I want to change to 19"'s on my 55plate exterior facelift vogue. How do I know if tpms is fitted and if so, If I fitted a set of new landrover wheels would the sensors just work or would they need 'pairing' to the car?
Post #13203 15th Feb 2010 2:22pm
dan_uk_1984
There is a button on the dash that looks like a flat tyre with an exclamation mark. Opposite the DSC button I believe, under the parking sensor button.
Post #13209 15th Feb 2010 3:20pm
dan_uk_1984
And in response to OP I know is not the answer you are looking for buy you can buy replacement sensors, you have to make sure you get the correct frequency, but I "think" BMW ones (around £30) will work.
Dan
Post #13210 15th Feb 2010 3:21pm
Vogue
Sidney, as far as I am aware this only became available on the 07 MY onwards
Post #13217 15th Feb 2010 4:06pm
dan_uk_1984
It's been optional fit since 2002.
Post #13218 15th Feb 2010 4:12pm
Vogue
Dan, there you go learn something new every day Thumbs Up was it standard fit then from 07 ?
Post #13223 15th Feb 2010 4:20pm
dan_uk_1984
I think you are right there. Isn't TPMS mandatory in the US now (maybe from 2007?) I suppose it's easier for LR just to install it as standard on every car now than mess about.
I've been interested in retrofitting the system to mine, not impossible, but a little too expensive for me to seriously consider it.
Fact of the day:
There are two types of TPMS.
1. Wheel sensors with RF Senders and Receivers monitor the pressure of the air in the tyre and relay that to a TPMS ECU.
2. The ABS ECU calculates the rolling diameter of each wheel & tyre, a flat/low tyre will be smaller and have to turn more in comparison to fully inflated wheels.
BMW uses both of above, but only 1. fitted to BMW X5/ Range Rover.
The RR system liaises with the vehicle alarm and is constantly "active" it will sound the alarm if there is rapid deflation of any of the wheels (tyre being slashed).
Post #13226 15th Feb 2010 4:38pm
Look at the wheel valves, if they are boring rubber ones they are not TPMS, if they look like metal bolts with a hexagon base, they are TPMS. Discovery 4 HSE
1993 90 Tdi
Post #13229 15th Feb 2010 5:13pm
Sidney
Looks like its not on mine thankfully, makes changing the wheels easier! Thanks guys, sorry to Hijack. Smile
Post #13246 15th Feb 2010 8:33pm
