![]() | Home > In Car Electronics (L322) > TV in motion |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
afaik you cant unlock the factory units for video in motion..the only way is to fit an aftermarket unit to to this.. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
hi sorry for delay in reply, been on holiday.
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
The 753 hack works perfectly for me to watch tv on the move. No need to buy/connect anything. Range rover td6 54 reg touch screen |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
It works for me also, but its far from convenient to enable and you have to select the channel you want to watch first. ![]() Gone - Range Rover Supercharged 2006 ![]() |
No. Im able to change channels from the steering wheel once in the menu. And even select radio or cd and back to tv. No issues at all Range rover td6 54 reg touch screen |
I can change through a few channels from the steering wheel controls, but not the entire list that I can see when in park with the handbrake applied. |
Hi justinp, once in the hidden menu and with tv on try pressing the menu button and you should be able to select the radio/cd/tv. You can also used the forward and previous keys to select stations aswell as steering wheel. Range rover td6 54 reg touch screen |
Daniel2007VogueSE Member Since: 30 Jul 2012 Location: Singleton NSW Australia Posts: 17 ![]() ![]() ![]() |
Hi Stu I have a 2007 tdv8 vogue SE with the luxury rear ICE fitted. It has TV, DVD, SatNav, VentureCam and Phone. As you would know, the VentureCam, TV, SatNav and phone features are all turned off whilst moving at a certain speed. Does fitting the device you have fitted allow you to operate the listed devices at any speed? I look forward to your advice. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
AFAIK, the sat nav input on the move has to be a software update by your dealer. I have a 2008MY Vogue SE and this is enabled on mine out of the box, earlier cars can be done. I think this one also covers being able to muck about with the phone too, as you get the update that pulls down the phone's directory via bluetooth too.
nav on the move can also be activated with the IIDTool... ... - .- -.
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
can it be activated via 753 ? |
it can be viewed via 753 but not activated.. ... - .- -.
My VentureCam is dead as the previous owner never used it and the battery cells died. I'm in the process of reviving or replacing them. From other posts I understand that the VC is disabled as anything above 20 kph. IIDTool? - not familiar with that one - I have Hawkeye. |
