Home > In Car Electronics (L322) > TV in motion
Page 2 of 4 <1234>
stu
well fitted my VIM this morning and all is well, my passengers can now watch TV on the move if they so wish.
was quite an easy process really, just took my time and watched some on line video gides first as suggested. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #75127 7th Aug 2011 2:30pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
Hi
I am trying to upgrade my factory fitted analogue tuner todigital tv (DTV) and lookingn for someone who has installed a unit like this;
http://www.tv-in-motion.co.uk/
Did you install a plug and play TV in motion unit, or are you just referring to unlocking the factory fitted hybrid or digital tuner??
thanks
Post #78406 30th Aug 2011 11:41pm
afaik you cant unlock the factory units for video in motion..the only way is to fit an aftermarket unit to to this..
Post #78419 31st Aug 2011 8:54am
stu
hi sorry for delay in reply, been on holiday.
yes i fitted a plug and play unit like the one in your link. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #80209 10th Sep 2011 9:31am
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
The 753 hack works perfectly for me to watch tv on the move. No need to buy/connect anything. Range rover td6 54 reg touch screen
Post #82052 17th Sep 2011 7:46pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
It works for me also, but its far from convenient to enable and you have to select the channel you want to watch first.
Gone - Range Rover Supercharged 2006
Post #82057 17th Sep 2011 7:57pm
tanertimur
No. Im able to change channels from the steering wheel once in the menu. And even select radio or cd and back to tv.
No issues at all Range rover td6 54 reg touch screen
Post #82290 18th Sep 2011 10:11pm
JustinP
I can change through a few channels from the steering wheel controls, but not the entire list that I can see when in park with the handbrake applied.
Post #82291 18th Sep 2011 10:17pm
tanertimur
Hi justinp, once in the hidden menu and with tv on try pressing the menu button and you should be able to select the radio/cd/tv.
You can also used the forward and previous keys to select stations aswell as steering wheel. Range rover td6 54 reg touch screen
Post #82409 19th Sep 2011 3:10pm
Daniel2007VogueSE
Australia 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Hi Stu
I have a 2007 tdv8 vogue SE with the luxury rear ICE fitted. It has TV, DVD, SatNav, VentureCam and Phone.
As you would know, the VentureCam, TV, SatNav and phone features are all turned off whilst moving at a certain speed.
Does fitting the device you have fitted allow you to operate the listed devices at any speed?
I look forward to your advice.
Post #133538 30th Jul 2012 12:32pm
AFAIK, the sat nav input on the move has to be a software update by your dealer. I have a 2008MY Vogue SE and this is enabled on mine out of the box, earlier cars can be done. I think this one also covers being able to muck about with the phone too, as you get the update that pulls down the phone's directory via bluetooth too.
The Venturecam thing I have never tried in detail, but I know you can watch the venture cam on the move as standard. Discovery 4 HSE
Post #133547 30th Jul 2012 1:04pm
nav on the move can also be activated with the IIDTool... ... - .- -.
Post #133558 30th Jul 2012 1:56pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
can it be activated via 753 ?
Post #133613 30th Jul 2012 4:58pm
it can be viewed via 753 but not activated.. ... - .- -.
Post #133620 30th Jul 2012 5:42pm
Daniel2007VogueSE
My VentureCam is dead as the previous owner never used it and the battery cells died. I'm in the process of reviving or replacing them. From other posts I understand that the VC is disabled as anything above 20 kph.
IIDTool? - not familiar with that one - I have Hawkeye.
Post #133657 30th Jul 2012 9:33pm
Page 2 of 4 <1234>
