![]() | Home > In Car Electronics (L322) > TV in motion |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
craig,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Stan, Thanks for the response pal... How or where did you find your nav version? As i looked and could not find it!
its in the '753' diagnostics bit..i did search each diagnostic section there but found it eventually.. ... - .- -.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Daniel...the module i fitted was in my face lift 2005 FFRR and it worked a treat for the TV and TV only. there was no nav input on the move but the venture cam works at all speeds anyway!!!
Daniel2007VogueSE Member Since: 30 Jul 2012 Location: Singleton NSW Australia Posts: 17 ![]() ![]() ![]() |
Thank you Stan, will look tomorrow... Craig ![]() |
craig...you seem to be a man in the know!!!
Daniel, just to let you know i have sorted VIM for my TDV8 now. i bought a good module and all seems to be well. that's Mrs. Stu happy again!!..... means i can get away with buying something else now... |
Daniel...my sat nav already works on the move always has!! the VIM module was required to keep TV picture on whilst on the move.
yes the SatNav may work but only in a quite limited manner. One cannot input any addresses or destinations - a lot of its functionality is disabled on the move (it is grey out and unavailable to use). Similarly the hard docked phone has its SMS features disabled whilst on the move. Makes a cheap Tom Tom Sat Nav that one can buy for $80 in the local supermarket more useful than the LR SatNav for which one has to pay $300 just for a map update DVD. 1989 RRC with GMC 6.5td 2005 L322 td6 HSE 2007 L322 tdv8 Vogue SE |
i have full functionality of the sat nav, always have, destinations. POI's etc all on the move. Didn't have it in my TD6, but all there now.
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
stu,can you please clarify.
goldsax, a 'tv-on-the-move' adapter will only give you that, it sometimes also shows 'p' or 'n' in your drive selection as its fooling the range into thinking its not moving..
