Home > In Car Electronics (L322) > TV in motion
Page 3 of 4 <1234>
stan wrote:
nav on the move can also be activated with the IIDTool...
Stan, did you get tp the bottom of the nav on the move pal? Mine still wont Sad
Craig Thumbs Up
Post #133670 30th Jul 2012 9:27pm
craig,
on the IIDTool q&a thread i submitted my nav version which seems is not compatible with that IIDTool function..for it to work i would have to flash my nav software to the correct version which isnt worth the hassle.
10th post down craig..http://www.fullfatrr.com/forum/topic12418.html ... - .- -.
Post #133692 31st Jul 2012 7:26am
Stan, Thanks for the response pal... How or where did you find your nav version? As i looked and could not find it!
Craig Bow down
Post #133859 1st Aug 2012 12:30am
its in the '753' diagnostics bit..i did search each diagnostic section there but found it eventually.. ... - .- -.
Post #133884 1st Aug 2012 9:51am
stu
Daniel...the module i fitted was in my face lift 2005 FFRR and it worked a treat for the TV and TV only. there was no nav input on the move but the venture cam works at all speeds anyway!!!
i tried to fit a module in my 2007 TDV8 and it wouldn't work!! it also through up suspension faults on the the display, so i removed it.
i too am looking for a solution to the TV issue...(for my passengers of course!!) don't want another lecture like i got last time about safety... Sad Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134413 5th Aug 2012 7:52am
Daniel2007VogueSE
Australia 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Thanks Stu
I couldn't believe all that c....p that people bather to lecture with - are there really that many forum users that work at local Councils???? and don't they get enough ego boosts out of telling ratepayers and developers on how to live their lives without becoming little hitlers and lecturing others on the forum?
As re VC - i've only just got mine working - the previous owner never removed it from its glove box charging socket and the cells reversed polarity - dismantled it and now got it going. Other forum posts complain that it stops working at anything over 20 kph.
It would be nice to get both full SatNav, phone and TV functionality whilst on the move! May be someone will come up with a patch/fix/diagnostic programming function one day soon. 1989 RRC with GMC 6.5td
2005 L322 td6 HSE
2007 L322 tdv8 Vogue SE
Post #134548 5th Aug 2012 9:03pm
Thank you Stan, will look tomorrow...
Craig Thumbs Up
Post #134556 5th Aug 2012 9:37pm
stu
craig...you seem to be a man in the know!!!
what's the easiest way to get good access to the radio module on a TDV8?????
any help/advice would be greatfully received. . Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #135467 11th Aug 2012 7:58am
stu
Daniel, just to let you know i have sorted VIM for my TDV8 now. i bought a good module and all seems to be well. that's Mrs. Stu happy again!!..... means i can get away with buying something else now... Laughing Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #136089 15th Aug 2012 7:24pm
Daniel2007VogueSE
Thanks Stu - what module did you buy? and does it enable full SatNav functionality or just the TV/DVD video? 1989 RRC with GMC 6.5td
2005 L322 td6 HSE
Post #136108 15th Aug 2012 8:40pm
stu
Daniel...my sat nav already works on the move always has!! the VIM module was required to keep TV picture on whilst on the move.
i bought this module.....
http://www.xcarlink.co.uk/product.php?prod...amp;page=1
but cheaper on ebay. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #136116 15th Aug 2012 9:00pm
Daniel2007VogueSE
yes the SatNav may work but only in a quite limited manner. One cannot input any addresses or destinations - a lot of its functionality is disabled on the move (it is grey out and unavailable to use).
Similarly the hard docked phone has its SMS features disabled whilst on the move.
Makes a cheap Tom Tom Sat Nav that one can buy for $80 in the local supermarket more useful than the LR SatNav for which one has to pay $300 just for a map update DVD. 1989 RRC with GMC 6.5td
2005 L322 td6 HSE
Post #136118 15th Aug 2012 9:24pm
stu
i have full functionality of the sat nav, always have, destinations. POI's etc all on the move. Didn't have it in my TD6, but all there now.
maps are easy to come by for not too much money if you know where to look, obviously that is europe, not sure about your part of the world, i will have a look though. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #136127 16th Aug 2012 4:29am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
stu,can you please clarify.
did the new unit allow you to get nav/sms etc on the move(ie input new distination etc) as well as tv ? cheers
Post #136143 16th Aug 2012 8:23am
goldsax, a 'tv-on-the-move' adapter will only give you that, it sometimes also shows 'p' or 'n' in your drive selection as its fooling the range into thinking its not moving..
nav-on-the-move can be activated by something like the GAP IIDTool .. ... - .- -.
Post #136149 16th Aug 2012 8:35am
Page 3 of 4 <1234>
