Home > Maintenance & Mods (L322) > Starting woes!
Page 1 of 3 123>
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Starting woes!
Symptom: car starts ok 1st thing then gets more temperamental as the day goes on. Starting has become more laboured with in excess of 30 secs. crancking on the key not uncommon.so far have replaced the battery, external pump at fuel tank, pressure sensor that's fits on the end of the fuel rail. Don't have a code reader so will have to visit the garage yet again.at this point I am just throwing money at the car car in the vain hope that it will eventually be cured. Don't get me wrong, love the car but am losing the will to live with so many problems arising all too frequently.
47p2, cps sensor , is that an easy/ inexpensive fix?
If an injector was faulty, would the car not run lumpy?It runs great once started with no smoke from exhausts.
While getting the fuel pressure sensor done, all fuel lines checked and were seemingly all ok now, there was a small leak pre sensor fitment, but ok now.
Any ideas greatly appreciated at this point!
Post #134289 4th Aug 2012 10:36am
ebajema
I would think glow plugs although it is a "funny" problem. MY 2010 5.0 SC Galway green and sand interior!!
Post #134291 4th Aug 2012 10:50am
Doubt if it is glow plugs, even when we were down to -22C a couple of years ago I never used my glow plugs and the engine started first time
CPS usually goes wrong when the engine is warm, so if starting easily first thing in the morning and not starting when warm it is a possibility it could be faulty. Not sure on the cost, but they are not normally expensive
Post #134293 4th Aug 2012 10:54am
Mr Tee
Will give Dan a bell Monday , he hasn't given me his home number yet!
Post #134294 4th Aug 2012 11:00am
CPS is £32 from Eurofarts but out of stock
Post #134295 4th Aug 2012 11:02am
Mr Tee
Would it be an easy install, I can take hings apart but am useless at putting back on!
Post #134296 4th Aug 2012 11:06am
Mr Tee
Rimmers have them : is this the culprit: http://www.rimmerbros.co.uk/Item--i-NSC100880L a bit pricey from them though!
Post #134297 4th Aug 2012 11:09am
Check with Dan for the correct part number
Post #134298 4th Aug 2012 11:15am
Mr Tee
Wow, you are the font of all knowledge! Bow down
This seems like the next step, will get fault codes checked early in the week too.
As an aside, how do dodgy injectors manifest themselves ? I would have thought that some smoke would be produced, with pretty rough idle & running ? Is a leak back test a bit of a pain to conduct? What I mean to ask is could a dumbass with minimal knowledge & skill do it?
Post #134300 4th Aug 2012 11:24am
A dripping injector could cause difficult starting, but not necessarily cause smoke from the exhaust. Expensive to have diagnosed and repaired so making sure everything else is in order before going to the bother of removing them for checking.
Not sure if any of the home diagnostic tools will read the engine faults, but a LR indie with Autologic is a safe bet and should not be expensive.
Post #134301 4th Aug 2012 11:28am
Mr Tee
Sounds like I need a recommendation for a good indie in tayside, anyone any suggestions?
Post #134302 4th Aug 2012 11:32am
Yeah he's also known as Methuselah …. Laughing Laughing
Post #134304 4th Aug 2012 11:35am
Also may be worth just checking the wiring from the CKP back to the ECM ? .
Post #134309 4th Aug 2012 11:57am
I do Thumbs Up just not met you yet Laughing Laughing
Post #134311 4th Aug 2012 12:02pm
Pity i was down your neck of the woods on Thursday taking the wee one to the Orthodontist at Orchard Drive …. Thumbs Up
Post #134315 4th Aug 2012 12:37pm
Page 1 of 3 123>
