![]() | Home > Maintenance & Mods (L322) > Starting woes! |
I would think glow plugs although it is a "funny" problem. MY 2010 5.0 SC Galway green and sand interior!!
Doubt if it is glow plugs, even when we were down to -22C a couple of years ago I never used my glow plugs and the engine started first time
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Will give Dan a bell Monday , he hasn't given me his home number yet! |
CPS is £32 from Eurofarts but out of stock |
Would it be an easy install, I can take hings apart but am useless at putting back on! |
Rimmers have them : is this the culprit: http://www.rimmerbros.co.uk/Item--i-NSC100880L a bit pricey from them though! |
Check with Dan for the correct part number
Wow, you are the font of all knowledge! |
A dripping injector could cause difficult starting, but not necessarily cause smoke from the exhaust. Expensive to have diagnosed and repaired so making sure everything else is in order before going to the bother of removing them for checking.
Sounds like I need a recommendation for a good indie in tayside, anyone any suggestions? |
Yeah he's also known as Methuselah …. ![]() ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Also may be worth just checking the wiring from the CKP back to the ECM ? .
I do ![]() ![]() ![]() |
Pity i was down your neck of the woods on Thursday taking the wee one to the Orthodontist at Orchard Drive …. |
