Home > Technical (L322) > Towing with air susp. inactive message
Andy
As the suspension locks when towing, and mine is currently locked in standard ride height due to the above fault, will towing be a problem?
The suspension is still rising and falling on slopes etc, so I assume it's still working, just no control over the ride height switch which is illuminated.
Cheers 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #134439 5th Aug 2012 11:11am
Since towing locks it in normal hight I can't see a problem per-say . 2008 MY Supercharged
Post #134441 5th Aug 2012 11:13am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
+1 Thumbs Up just gone 650 miles with mine faulty no problem Mine was a blue one! Smile
Post #134446 5th Aug 2012 12:27pm
Andy
650 miles towing? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #134472 5th Aug 2012 2:49pm
Andy3681
Yep pity gearbox playing up now Big Cry Mine was a blue one! Smile
Post #134501 5th Aug 2012 5:23pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
+1
Mine was inactive for 6 months, I had to go for an MOT and an inactive air suspension is an MOT failure
so i had it fixed. it was an faulty steeringwheel sensor
Post #134977 8th Aug 2012 4:00pm
Andy
It's not an mot failure. I had the fault on mine when it went in for mot. The garage checked with VOSA and they said it was ok. Having said that, my mot was in March, so things could have changed since then. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #135265 10th Aug 2012 8:22am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
My suspension failure was also a Steering Angle Sensor - but this also caused the ABS light to come on, and its that that is the MOT failure... l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #135312 10th Aug 2012 10:50am
fisha
No problem towing with it I've that ... Mine throws the error all the time for the pressure static message and it's stayed in normal height for months including regular towing. I just can't be otherwd resetting it sometimes so it manages fine. V8 or else ...
Post #135346 10th Aug 2012 12:34pm
johnson1
It is an MOT failure if your vehicle is fitted with Xenons.
The air suspension keeps the vehicle level at all times which gets rid of the requirement to have the Xenons automatically adjust, hence why there is no 'up and down dance' of the lights on startup on the FFRR.
Post #135503 11th Aug 2012 3:45pm
If you have adaptive head lights they do do the dance Thumbs Up 2008 MY Supercharged
Post #135504 11th Aug 2012 4:17pm
if there is a load on the rear , ie a trailer/caravan then the range in standard mode will level out , if that happens then the xenons are directing their beam in the correct place, so how can this be a mot failure...or have i got the wrong end of the stick... ... - .- -.
Post #135505 11th Aug 2012 4:23pm
johnson1
If there is an 'air suspension inactive' message then the air suspension is not working properly, and therefore is not potentially levelling the vehicle correctly, and hence the reason for MOT failure. It is an offence to drive a vehicle with Xenons without some form of automatic levelling. This is why people that swap halogen bulbs for xenon bulbs are breaking the law on most vehicles.
Post #135506 11th Aug 2012 4:43pm
johnson1
Mine don't on 2011MY axle - is something wrong with mine?
Post #135507 11th Aug 2012 4:44pm
the OP , noddy , says his does level on slopes so that's ok, isnt it.. ... - .- -.
Post #135508 11th Aug 2012 4:49pm
