![]() | Home > Technical (L322) > Reduced engine performance and rear differential whine |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi Chaps,
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
Had that with the aux. coolant pump. All sorted under warranty. AFAIK the fuel pump stays quiet until 1/8th tank then cuts out, after a couple of restarts you'll get the low fuel pressure code.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Given that you were in S of F and have never had that issue before, then I'd say it may be the SC electric aux pump wiring due to elevated ambient temperatures.....
Colin - yes, I normally run my car very low and I've never experienced this before so it may be the aux pump issue, however when the fault occurred the temp gauge was showing normal temperatures.
At least you've still got warranty, if it the aux coolant pump, from memory it's about £120 and an easy fix.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Id say fuel pump, too much of a coincidence otherwise! 2012 SDV8 Vogue SE |
What was the external temp? I had this on my 2006 SC and it was the wiring issue. Land Rover Addict
The external temp was 31 C, but I drove the same route last year and it was just over 40 C without problems. |
Hi Chaps,
My thoughts confirmed, I was sure that the charge pump would be the problem |
The LR Warranty Company Assessor came out to check my rear differential today, and has agreed its bad enough to justify replacement. Thank bloody goodness, as the bill was looking like its going to be the wrong side of £1500 |
Great news about the diff!
My rear diff was replaced yesterda and my SC is silent again |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
its a good job you got that warranty, you've had your moneys worth ... ... - .- -.
