Home > eBay & Bargain Spots > Heatshot - Heated washer jet system great price
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
The Heatshot is an aftermarket system that creates a reserve of hot water in your washer system so when you need to clear ice bugs the warm water speeds up the process.
Also looks cool in winter when your jets release water and steam to clear the windscreen in super quick time!
These normally go for about £175-£200.
£99 plus £10 delivery.
http://www.ebay.co.uk/itm/HeatShot-/120955...463wt_1143
Seem to have good reviews and great for clearing the windscreen in winter and summer. I've ordered one, looks simple for installation.
Watch the video demo here:
Installation:
 Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #134812 7th Aug 2012 7:53pm
Looks okay , think i'll stick with my heated jets tho .. Thumbs Up
Post #134815 7th Aug 2012 8:05pm
Flashman
Well the older cars might not have the heated water reservoir system in place, I have no idea if mine has heated washer heads, but the water will still be cold, at least with this one the water his hot which would make a big difference in clearing.
If the new RRs have this as standard then great, but I am sure it would cost a fair bit more than £100 to retrofit. Tom
Current Drive
Previous Drives
Post #134817 7th Aug 2012 8:15pm
wouldnt a cold screen and hot water spraying onto it cause a bit of a problem.. ... - .- -.
Post #134818 7th Aug 2012 8:20pm
Flashman
Well it is 50 degrees so not boiling and it seems to work well according to lots of reviews on Defender and Discovery forums.
Here is one with lots of Q&As
http://www.ukspeedtraps.co.uk/heatshot.htm
I take it that the heated washer jets just stop the nozzles freezing. This system would work in addition to it, so that the ice or muck clears with fewer wipes.
It makes sense, as glass always clears better with warm as opposed to cold water. Tom
Current Drive
Previous Drives
Post #134821 7th Aug 2012 8:29pm
warm water on a frosted screen does work wonders...let us know how it all works out TOM.. ... - .- -.
Post #134826 7th Aug 2012 8:39pm
Flashman
Will do! Tom
Current Drive
Previous Drives
Post #134827 7th Aug 2012 8:42pm
Heated windscreen anyone? Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #134828 7th Aug 2012 8:42pm
Thats Right forgot about that and the FBH Whistle
Post #134830 7th Aug 2012 8:44pm
Flashman
Ok guys, I understand that all of you with 10-30 minutes on your hands can prep the car with the FBH and heated screen. But in my experience, if I need to suddenly use the car and don't have time to wait then the FBH and heated screen are far too slow.
Anyway, I really want steaming nozzle jets. Laughing Tom
Current Drive
Previous Drives
Post #134836 7th Aug 2012 8:54pm
Laughing Laughing
Posting for next January …
Steaming Jets Cracked my windscreen … Laughing Wink Wink
Post #134838 7th Aug 2012 8:57pm
To be honest it won't be 50'c when it hits the screen so should be fine and the heated elements do the same, col screen quickly being heated above 0'c same affect really Smile
New screens resist this so much better as just think how cold it gets outside at speed yet how warm the screen on the inside is with hot air hitting it on one side and freezing air at say 70mph hiring the other side...
On cars without heated windscreen or fbh I've always used luke warm water to melt the screen and put some heat into it and then on the washers if frozen as that bit of extra heat in the glass helps for the first few miles until the engine is warmed enough Smile
It will be fine Thumbs Up FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #134846 7th Aug 2012 9:07pm
Flashman
You'll all be jealous as I steam past you.....
I think it will be fine, and it is not a huge outlay for another gadget. Tom
Current Drive
Previous Drives
Post #134853 7th Aug 2012 9:32pm
10-30mins... So how long will it take your element to melt/heat the screen resevoir before the washers will work my friend?
Craig Whistle
Post #134864 8th Aug 2012 12:07am
It would depend on the element Wink
I've seen quick ones using some kettle elements before now. Obviously Heath Robinson styled but very effective Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #134865 8th Aug 2012 12:09am
