Home > Technical (L322) > BATTERY DRAIN
Page 1 of 3 123>
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
BATTERY DRAIN
HI
had the dreded battery drain put on a new bosch battery as recomended on ffrr , the new battery drained after about 7 days( away on hols) , so changed the final stage resistor, charged the battery off the rr, put battery back on rr , did a amp load check with a meter,found when rr locked the current draw the meter was 3.2amps. then , after 20 mins the rr went to sleep ,and the current draw was 0.5 amp .does this seem normal? or do i need to look for any other faults
thanks 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135334 10th Aug 2012 11:44am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
0.5A still seems a little high.
That means a 110 A/H battery would be dead in a week (168 hours) as you have experienced.
Start by pulling out fuses one by one until the drain drops - that might help give you a clue what's causing it. The other possibility is the diode pack in the alternator is on its last legs Sad
Post #135335 10th Aug 2012 11:46am
what simon says and also ,check your OBD port is closed... ... - .- -.
Post #135336 10th Aug 2012 11:48am
Simes
Oh- yes top tip - he says somewhat shamefacedly... Guess who did that recently then Stan!
Post #135337 10th Aug 2012 11:51am
uuummmm, [thinks hard] .......you! Laughing ... - .- -.
Post #135338 10th Aug 2012 11:55am
STEVE57
ok. i will check. what current draw should i expect when rr is asleep?
thanks
steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135339 10th Aug 2012 11:56am
Simes
A very few milliamps I would think. Not more than 100 mA.
Post #135345 10th Aug 2012 12:31pm
Simes
Yup...
Ran around happily for a fortnight (while waiting for the lead from Storey) and only noticed the other weekend - went caravanning and wondered why, in the dark of the night, the gear console was still lit up 4 hours after parking and locking the car...
Post #135348 10th Aug 2012 12:41pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Curious (might have missed the thread this was mentioned in) - why is this Stan??
Post #135370 10th Aug 2012 2:52pm
it seems that the lid has contacts in it and they complete a circuit when closed.. ... - .- -.
Post #135371 10th Aug 2012 2:54pm
Saint.v8
Oh I see....
Ta.
Post #135373 10th Aug 2012 2:57pm
STEVE57
Re: BATTERY DRAIN UPDATE
STEVE57 wrote:
HI
thanks
UPDATE
Changed nav drive now current draw in sleep mode is 0.16 amps (160ma) is this acceptable ?
or do i need to look further?
thanks
Post #135615 12th Aug 2012 3:41pm
Andy
I was going to start a new post on battery drain this week whilst on holiday. I suffered a flat battery and I'd not long fitted the big Bosch 5 yr warranty jobbie.
What I noticed was the jump lead post that is mounted on the plastic bulkhead type trim had melted the surrounding plastic and cap both sides. On closer inspection, it looked like this post had got incredibly hot at some point, hence the damage. I removed the leads from both sides of the post and cleaned them up, before bolting them together. It's been fine since then.
I can only assume that charge hasn't been getting to the battery due to poor conductivity and it's steadily gone flat. I don't think I'll bother replacing the jump lead post either. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #135646 12th Aug 2012 8:02pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
STEVE57 wrote:
STEVE57 wrote:
HI
thanks
UPDATE
thanks
steve
Hi Steve
It's still abit high, I would start checking for other live circuits. I always aim for the drain to be around 0.01A to 0.02A when I'm fixing a battery drain fault.
Post #135656 12th Aug 2012 9:48pm
STEVE57
Hi brian
I wiil have to keep looking. Where shall i start?What fuses would you suggest to start with?
Thanks
Steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135662 12th Aug 2012 10:06pm
Page 1 of 3 123>
