Home > Technical (L322) > HELP URGENT
Page 1 of 4 1234>
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
HELP URGENT
Hi gang got 52 plate td6 brake lights are lit when key is out and cant get ignition key to turn ,also alarm indidcaters dont flasham stuck need car asap any help or any one near stockport can give assistance
regards pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136226 16th Aug 2012 3:09pm
if the key doesnt turn then it could be the 'mechanics' under the console ....console off and have a look.
this is related. http://www.fullfatrr.com/wiki/Key_stuck_in_ignition ... - .- -.
Post #136228 16th Aug 2012 3:13pm
trainmanone
have looked at that stan but the stearing whill normaly comes out befor i turn the key and its not doing,pluss the brake lights are lit without the key in and indicator lights for alarm arnt working
Post #136229 16th Aug 2012 3:20pm
try a battery disconnection then, again details in the wiki......its a process of elimination pete.. ... - .- -.
Post #136232 16th Aug 2012 3:26pm
trainmanone
Stan ,its the longest 15 mins ive ever known lolkeeping my fingers crossed have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136235 16th Aug 2012 3:36pm
if this doesnt help then you need to have an expert look at it..the range has so many ecu's inter connected that when one goes down an un-related problem shows up somewhere else... ... - .- -.
Post #136236 16th Aug 2012 3:39pm
Could be a faulty brake light switch
Post #136238 16th Aug 2012 3:48pm
trainmanone
well i need an expert its still the same ignition wont turn brake lights lit with no key in at a toltle loss now ,whish i had kept my omega now
Post #136239 16th Aug 2012 3:49pm
Have you tried the spare key? Just wondering if the battery has gone in your key and the lock is not coming off. Previously..
Post #136240 16th Aug 2012 3:54pm
trainmanone
yes tried that was ist thing i did try
found this on another site
The brake lights are activated by the LCM (Light Check Module) which is located on the drivers side (RH side) A post (where your right foot is when you are driving) behind the trim panel. This should be your first point to check. The brake lights are activated when you press the brake pedal (obviously) and also when HDC is enabled.
When this fault occurs, do you hear the steering lock come off when you put the key in? (this happens to me)
what is th HDC??
Post #136242 16th Aug 2012 3:57pm
when you put your key in and before you turn the key you should hear a clicking , if not try another key like contraband suggested.. ... - .- -.
Post #136243 16th Aug 2012 3:58pm
trainmanone
all ready tried that now im getting all agitated dont know any good range rover mecanic and cant afford stealers prices
might have to sell it
Post #136245 16th Aug 2012 4:03pm
do you hear a clicking noise pete? ... - .- -.
Post #136247 16th Aug 2012 4:06pm
trainmanone
no nothing but the seat moves lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136250 16th Aug 2012 4:15pm
if the key dont click, you wont be able to turn it ...hows the fullfats battery , if its over about 3 years old it might need replacing.. ... - .- -.
Post #136252 16th Aug 2012 4:17pm
Page 1 of 4 1234>
