Home > Technical (L322) > Air Susp Inactive fault traced using RSW Allcoms
Andy
Fault said "left height sensor" - had a look underneath and..... no sensor! It's missing Laughing
Trip to the dealer tomorrow for a new one 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136309 16th Aug 2012 7:50pm
Shocked
Post #136311 16th Aug 2012 7:53pm
Andy
There's a cable hanging in mid air that seems to come from the black rectangular box above it. I'm guessing I'll need that too, as it looks (from the other side) that its all one piece 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136319 16th Aug 2012 8:00pm
Andy
you can see what's left of the cable and the missing sensor/link arm
Regarding the cable- is that hard wired into the black box that's mounted to the chassis?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136337 16th Aug 2012 8:58pm
There should be a connector plug on the end of the wire that plugs into the sensor
Post #136339 16th Aug 2012 9:08pm
Andy
Yeah, I'm assuming that's been ripped off. I'm also guessing that said plug isn't available to buy and is part of the cable- which I'm guessing is a direct connection to the black box? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136346 16th Aug 2012 9:30pm
You might have to visit a scrap yard and acquire one and splice it into the original wiring
Post #136352 16th Aug 2012 9:55pm
Andy
I've found the plug. It's available as a short harness so that a repair can be made.
If its any good to anyone, the part numbers are:
Ride Height Sensor: LR020636
Wiring/Plug for above: YMQ503220
http://www.lrseries.com/resources/user/78a...ARNESS.jpg
Just about to order the sensor from Duckworths, all being well! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136498 17th Aug 2012 12:40pm
Andy
Wel the parts arrived yesterday. Managed to get a replacement plug off eBay and soldered that into place. Fitted the sensor and bracket etc then connected Allcomms.
Before I'd fired the programme up, the fault message cleared.
Bit puzzled by that as my understanding was, faults remained until cleared? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137329 23rd Aug 2012 8:30am
Sounds like a win-win there fella Smile
Though how on earth did it get ripped off in the first place as something must have flown up and impacted it?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #137333 23rd Aug 2012 8:45am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Joining in late but yes as Noddy found they do a repair kit for the plug.
Just a note mine threw this error up a lot I replaced sensor and plug because code reader said nearside front sensor earth fault and it came up as faulty on off road screen on dash.
Fault kept re-occuring.
Then eventually common sense took over and looked at offside one. Plug was damaged and cable routed wrong so it was trapped!!.
apparently its not unknown for the wrong plug to go in the wrong socket on the suspension control module!!
not had it out to check but since I re routed cable to offside plug and cleaned it all up not had a fault! (fingers crossed) Mine was a blue one! Smile
Post #137339 23rd Aug 2012 9:15am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
getting similar suspension issues so invested in an RSW Allcomms and an looking forward it what it tells me Sad "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #137360 23rd Aug 2012 10:22am
MrP
Just had the quotes back from Dan on the height sensors - fronts are less than 20 quid LH rear is less than £30 but the RH rear is £75 quid!
Whats the betting the RH rear is the one that goes most often........
Have to wait for my RSW AllComms to turn up and let me know which is at fault. "On first name terms with my local Dealer......now."
Post #137411 23rd Aug 2012 2:28pm
Ask him to check that price, both rears for mine were the same price from Shields LR
Post #137414 23rd Aug 2012 2:35pm
Andy
Less than £20? He charged me £27! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137491 23rd Aug 2012 10:55pm
