![]() | Home > Technical (L322) > Air Susp Inactive fault traced using RSW Allcoms |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Fault said "left height sensor" - had a look underneath and..... no sensor! It's missing |
There's a cable hanging in mid air that seems to come from the black rectangular box above it. I'm guessing I'll need that too, as it looks (from the other side) that its all one piece 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
you can see what's left of the cable and the missing sensor/link arm
There should be a connector plug on the end of the wire that plugs into the sensor |
Yeah, I'm assuming that's been ripped off. I'm also guessing that said plug isn't available to buy and is part of the cable- which I'm guessing is a direct connection to the black box? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
You might have to visit a scrap yard and acquire one and splice it into the original wiring |
I've found the plug. It's available as a short harness so that a repair can be made.
Wel the parts arrived yesterday. Managed to get a replacement plug off eBay and soldered that into place. Fitted the sensor and bracket etc then connected Allcomms.
Sounds like a win-win there fella |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Joining in late but yes as Noddy found they do a repair kit for the plug.
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
getting similar suspension issues so invested in an RSW Allcomms and an looking forward it what it tells me |
Just had the quotes back from Dan on the height sensors - fronts are less than 20 quid LH rear is less than £30 but the RH rear is £75 quid!
Ask him to check that price, both rears for mine were the same price from Shields LR |
Less than £20? He charged me £27! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
