![]() | Home > Technical (L322) > Front Suspension Depressurising |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Ill try tracing the pipes but they go in to the body/subframe where the reservoir is located.
Hi just an update.
It does have a plastic cover protecting it (not very well as its covered in |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Perhaps the car had an accident? Therefore they have changed the position of the valveblock??? If you have compressor problems, test him for the pressure of 13,7 bar.... only with the correct pressure the complete suspension can work as bloodbrothers.
I'm pleased you found it and were able to de-pressurise OK.
This are different blocks on the two photos..., the last photo from Bob the B is the original block under the right door, which is directly connected with the reservoir, (the reservoir is right!! on the photo), the photo from Joe90 is the original block for the front struts, but at Bob the B first photo we see the cable hanging around, very mystery because of the ECU ??? The suspension pipe for the left strut seems to be connected with a little plasticpart, but how can the complete suspension run without electronic function?
Aha, the plot thickens.
@Meerbush You are correct they are different blocks. It is as Joe 90 says the pic I have is the valve block assembly. The one I am missing is the cross link valve.
I'm guessing it all works height wise, but that the car body won't "self level" when an axle is articulated, so a bit like being on coils. That, as I understand is what the cross links are for, and these only come into play in off road height. .
Just had a quick measure of the four corners and the rears were 78/79cm from bottom of rim to under wheel arch and the fronts were 81/82cm from bottom of rim to under wheel arch, so almost level in off road mode.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Can the cross link valve block be viewed without taking the arch liner out? Can anything be peeled back to see if it's there? I fancy having a look to see if it have one. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Yes.
But how is the function ok when the cable of the front block is disconnected, normalywise must be a yellow LED in the dashboard to see..., a little mistake, not a heavy one. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Meerbusch all I know is that I now have my FF with working suspension again.
