![]() | Home > Maintenance & Mods (L322) > Coolant flush |
Just use a hose pipe to flush it all around |
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 ![]() ![]() ![]() |
Would getting the car up to temp with the heaters on, then opening the drain get rid of all the coolant? Or will some be left in there?
Last time I changed the rad I only got out about 5L so I need some other way of completely draining it, wheres this drain on the block?
You'd need to check RAVE to see where it is on the 4.4 but the idea of getting it up to temp is a good one.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Here's the info you need, with photos |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
4.4L V8 Cooling system capacity:
