Home > Maintenance & Mods (L322) > Coolant flush |
Just use a hose pipe to flush it all around and back flush though you may need to pour some boiling water in to open up the stat and let that out.
29th Aug 2012 8:58am |
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 |
Would getting the car up to temp with the heaters on, then opening the drain get rid of all the coolant? Or will some be left in there?
29th Aug 2012 8:59am |
Last time I changed the rad I only got out about 5L so I need some other way of completely draining it, wheres this drain on the block?
29th Aug 2012 9:02am |
You'd need to check RAVE to see where it is on the 4.4 but the idea of getting it up to temp is a good one.
29th Aug 2012 9:37am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Here's the info you need, with photos
29th Aug 2012 10:16am |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
4.4L V8 Cooling system capacity:
30th Aug 2012 9:13pm |
