![]() | Home > In Car Electronics (L322) > Engine Code on Nav screen |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
hi there and welcome to the forum..
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I think if you put the key in the ignition and turn to the first stop the CODE will be highlighted in white.
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Yes, that's what happens on mine. When the engine is running its greyed out. As the ignition key is turned to position 1, it lights up, and I can enter a code, it then says something like "remove key to activate" |
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 ![]() ![]() ![]() |
Thank you so much Stan , Budgie and Tsadpt. after reading your replies i was able to activate the code and registered a new code but there something strange happened !! i was able too to start the engine without entering the code !!! please see the picture and the video clip i have taken http://www.flickr.com/photos/78049469@N06/.../lightbox/ Thank you Ahmed |
possibly you didnt save the new code? [if there is a 'save' that is] ... - .- -.
i'm not familiar with that setup as i have a touch screen on mine, but you could try a battery dis-connection..this 'might' reboot the ecu's and set them to default....if you do remember to turn the steering wheel fully let then fully right after you have re-connected the battery [with engine running] ...procedure is on the wiki.. ... - .- -.
Thank you Stan
cant see that affecting the firmware as normally a newer sat nav disc just updates the nav firmware.. ... - .- -.
Thank you stan anyway |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
Where is the firmware for the computer screen actually stored ?
