Home > Technical (L322) > seatbelts
Rockportpurple
2002 Range Rover Vogue 4.4 V8 Giverny Green
seatbelts
hi guys does anybody know if there is a fix for the retraction on the seatbelts?
mine has stopped going back in and its annoying and wondered if there was a repair/fix as mine are green and dont fancy buying new ones
any help appreciated
regards
clive
Post #142871 25th Sep 2012 9:02am
Clive, update your car profile and you may have more luck my friend... There are probably 15-20 different seat belts through the years in a ff...
Im guessing if they are green you drive an 03/04 Vogue? Take the front "B" pillar trims off and clean the inner runner/plastic slider the seatbelt travels through...
Craig Thumbs Up
Post #142875 25th Sep 2012 9:09am
Rockportpurple
hi craig
thankyou for your reply yes it is an 02 plate giverney green vogue
its to the point where i have to sit and slide it back in by hand before i get out of the car such a pain i have caught it in the door twice and scratched the paintwork
ill try the slider thankyou very much for your help
regards
clive
Post #142878 25th Sep 2012 9:19am
I had this issue. A quick fix is use polish (pledge/mr shine) on the guide where it goes into the pillar. Hasn't cured the problem but a lot better untill I get time to strip it properly. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #142945 25th Sep 2012 1:08pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I find that the FFRR seatbelts are very slow to retract at the best of times, but as you've just said Clive, a good spray of furniture polish makes a real difference.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #143086 25th Sep 2012 10:55pm
