Home > Technical (L322) > Strange temperature gauge
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I dont think a thermostat is that expensive, around £30-£40 from a quick google search. its basically just a valve with a wax block in, when the wax block melts the valve opens. will need to replace coolant also.
Here is a video showing how to change one. (V8 M62 model tho)
Interesting video on how one works
Post #103314 24th Jan 2012 3:20pm
dan [duckworths] is the best place to get the thermostat and you'll need fresh coolant as well. ... - .- -.
Post #103316 24th Jan 2012 3:24pm
duckworthparts
Site Sponsor
£38inc vat for genuine
OEM one £29inc vat You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #103319 24th Jan 2012 3:37pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Fantastic which ever is better,
How much for a rad?
Just on motorway with heaters all off and
Gauge is bang on centre.
Then heaters on and it drops then yoyos
A little
I'm thinking it's the stat now as you all say,
If it was the pump it would be boiling over wouldn't it? RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #103324 24th Jan 2012 4:03pm
Katash
I would think if the pump fails or thermostat stays shut the temp would raise above a safe level.
By the way, have you noticed any drop in mpg? .... I read that if the engine is running below nominal temp the fuel condenses in the cyls and reduces performance and efficiency (not sure if this just applies to petrol engines tho)
Post #103327 24th Jan 2012 4:15pm
Ignore the V8 stuff, that's a walk in the park compared to the TD6 Wink .
Post #103359 24th Jan 2012 7:36pm
Jr-auto-electrics
What you say joe
Is it hard to change??? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103360 24th Jan 2012 7:41pm
http://www.fullfatrr.com/forum/post94803.html?#94803
and photos
http://www.fullfatrr.com/gallery/thumbnails.php?album=380 .
Post #103390 24th Jan 2012 10:42pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
My SC has the same issue with the temp gauge. When we had the cold spell the other day the temp gauge barely got off the blue on a 40 mile journey and I wasn't getting any hot air through into the cabin. Time to investigate I think.
Post #103415 25th Jan 2012 8:12am
It's a new thermostat she needs Nick , I was going to get it done before I traded her in , reason for not doing so
£16 for the thermostat
Dealership price for fitting £300 Shocked
Post #103420 25th Jan 2012 8:57am
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Is the access easier on the S/C? I, too, have the swinging temp issue!
There are some pics on the Jag forum for the 4.2 S/C engine and it seems to be at the front of the engine. And less gudel than Joes very good walk through.
This combined with the binding caliber and the reduced engine performance warning is my welcome to S/C ownership. (In respect to the engine warning I have checked the wiring to the aux coolant pump and it is wired correctly).
Grant
Post #103431 25th Jan 2012 10:18am
Jr-auto-electrics
9 months later
I finally got round to changing my thermostat and rad today 3 hour job and new viscous fan spanner Very Happy
Spot on guys it was the thermostat, now stops at the correct temperature while driving. Razz Razz
I've had the low coolant warning a few times in the last few weeks but the coolant was correct
So I removed the header tank and washed it out around ten times
I removed a load of scale from the tank, this was making the float sensor stick
And giving me a fake reading.
All sorted now Thumbs Up RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #145018 6th Oct 2012 2:50pm
RRG
Funny - I now seem to have the exact same issue - this topic was extremely useful - thanks!
Post #145809 10th Oct 2012 3:11pm
