Home > Maintenance & Mods (L322) > HDC Inactive - Can it be linked to wear on driveshaft?
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hello all,
I've been getting the HDC Inactive, Suspension lowered message for a while now with the "3 amigos" on the dash. Fault reading with the iid tool came up as "Front Right Wheel Speed Sensor Open Circuit" which Patrick at GAP [ut down to either a wiring (cut, corroded) or a sensor problem. I've had the car at the mechanics and what he has said is that he cant see any issues with the wiring and that the sensor is new.
He is now putting the error message down to a worn driveshaft Big Cry - and says that a couple of teeth (I assume he means splines) on the shaft are worn. Before I embark on a rather expensive drive shaft replacement exercise, any thoughts as to whether this makes sense ... or is that a totally unrelated issue to the HDC Failure?
Many thanks for your help! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #146616 16th Oct 2012 3:19pm
might be wrong but suspect that its not the driveshaft.. i've been told [eldest son who is a mechanic] that you can test the sensor by unplugging it and testing with an ohm meter... apparently if it has resistance then its ok , if no resistance then the wiring or sensor is faulty.. ... - .- -.
Post #146618 16th Oct 2012 3:34pm
I would have thought the same as Stan. As he doesn't know I would start with the cheap option an change the sensor for an OEM part and then investigate the drive shaft option. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146619 16th Oct 2012 3:37pm
DeRanged Rover
We have changed the sensor and were still getting the fault. I am convinced its a wiring issue but the mechanic is insisting that there is wear on the drive shaft and that is what is causing the problem. Might just get a second opinion from someone first before I change anything. African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #146620 16th Oct 2012 3:40pm
Did you get an OE sensor? They have been known to be supplied broken. I would try Stans sons method of testing. How many miles has your FF done? I've never heard of worn drive shafts on these cars yet but not impossible. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146623 16th Oct 2012 4:30pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I dont think a worn driveshaft would cause this unless it was slipping and if that was happening there would be more than 2 'teeth' worn. Ask him to explain why he thinks it is the cause.
Post #146635 16th Oct 2012 7:04pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
If the driveshaft was slipping, you would know about it - they don't fail a bit at a time - it would be stripped out and you would hear it - the TC would also be doing wierd Censored .
The IID tool will show you if the sensor is working - if it is not showing anything, then check with a meter at the sensor - if that is ok, then you have a wiring issue.
Post #146789 18th Oct 2012 12:07am
DeRanged Rover
Thanks All,
I'm going to take it to someone else to do the testing for me as have lost faith in the other chappie. I'll let you know how I get on.
Mileage is 94K so I'd be surprised if the drive shaft was slipping. He said something about a trigger wheel and teeth being worn - does that make any sense? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #148061 25th Oct 2012 3:40pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
In a word, No it doesnt make sense, unless i am much mistaken, and the range rover system works differently to allmost all other cars, it works by a magnetism effect, the wheel has nothing to wear against.
Regards, luke
Post #148107 25th Oct 2012 7:13pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Isnt there a switch under the brake pedal for the hdc ? That plays up
Also ive had hdc faults when the battery was playing up onto no6 Range Rover
Everyone needs a hobby
Post #148116 25th Oct 2012 7:30pm
Never heard of a switch on the brake pedal for the HDC. Please tell me more. Shocked always hand to know how this witchcraft works. Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #148132 25th Oct 2012 8:31pm
speedymarktd6
Im pretty confident there is a switch in with the brake pedal thats associated with the hdc ive never changed one but im sure there is one there as if you google hdc faults for l322 range rover it does come up onto no6 Range Rover
Post #148141 25th Oct 2012 9:03pm
Thanks. Will look into it for the inevitable HDC fault I'm bound to get. Lol [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #148143 25th Oct 2012 9:30pm
fisha
It might not be a case of the teeth being worn, but more a case of rusty gunk being stuck between the teeth. The result being that it creates a flat spot at the height of the teeth with the same effect as missing teeth. I found this when I replaced a sensor on mine.
May be worth taking the sensor out and look down the hole at the teeth and use a screwdriver to clean out the grooves if needed.
Also, the sensor cables can rub on the side of the wheel wall on the front as they wrap around the strut. Check them for wear. V8 or else ...
Post #148155 25th Oct 2012 11:01pm
