|  | Home > Maintenance & Mods (L322) > HDC Inactive - Can it be linked to wear on driveshaft? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881    | might be wrong but suspect that its not the driveshaft.. i've been told [eldest son who is a mechanic] that you can test the sensor by unplugging it and testing with an ohm meter... apparently if it has resistance then its ok , if no resistance then the wiring or sensor is faulty.. ... - .- -.
|  16th Oct 2012 2:34pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | I would have thought the same as Stan. As he doesn't know I would start with the cheap option an change the sensor for an OEM part and then investigate the drive shaft option. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  16th Oct 2012 2:37pm |
| DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379      | We have changed the sensor and were still getting the fault. I am convinced its a wiring issue but the mechanic is insisting that there is wear on the drive shaft and that is what is causing the problem. Might just get a second opinion from someone first before I change anything. African Bush Junkie ... in London!
|  16th Oct 2012 2:40pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | Did you get an OE sensor? They have been known to be supplied broken. I would try Stans sons method of testing. How many miles has your FF done? I've never heard of worn drive shafts on these cars yet but not impossible. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  16th Oct 2012 3:30pm |
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700      | I dont think a worn driveshaft would cause this unless it was slipping and if that was happening there would be more than 2 'teeth' worn. Ask him to explain why he thinks it is the cause. | ||
|  16th Oct 2012 6:04pm |
| The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155      | If the driveshaft was slipping, you would know about it - they don't fail a bit at a time - it would be stripped out and you would hear it - the TC would also be doing wierd   | ||
|  17th Oct 2012 11:07pm |
| DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379      | Thanks All,
|  25th Oct 2012 2:40pm |
| barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213      |
 In a word, No it doesnt make sense, unless i am much mistaken, and the range rover system works differently to allmost all other cars, it works by a magnetism effect, the wheel has nothing to wear against. Regards, luke | ||
|  25th Oct 2012 6:13pm |
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727      | Isnt there a switch under the brake pedal for the hdc  ? That plays up
|  25th Oct 2012 6:30pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | Never heard of a switch on the brake pedal for the HDC.  Please tell me more.  | ||
|  25th Oct 2012 7:31pm |
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727      | Im pretty confident there is a switch in with the brake pedal thats associated with the hdc ive never changed one but im sure there is one there as if you google hdc faults for l322 range rover it does come up onto no6 Range Rover
|  25th Oct 2012 8:03pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | Thanks. Will look into it for the inevitable HDC fault I'm bound to get. Lol [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  25th Oct 2012 8:30pm |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | It might not be a case of the teeth being worn, but more a case of rusty gunk being stuck between the teeth.  The result being that it creates a flat spot at the height of the teeth with the same effect as missing teeth. I found this when I replaced a sensor on mine.
|  25th Oct 2012 10:01pm |
| Posting Rules
 - and says that a couple of teeth (I assume he means splines) on the shaft are worn. Before I embark on a rather expensive drive shaft replacement exercise, any thoughts as to whether this makes sense ... or is that a totally unrelated issue to the HDC Failure?
 always hand to know how this witchcraft works.
