Home > Maintenance & Mods (L322) > Water free coolant
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Water free coolant
Saw this stuff on Wheeler Dealers the other evening...
Worth trying in a FFRR?
http://www.evanscoolants.co.uk/power-cool-...-cars.html
Apparently never needs changing - good for -40C to 180C... Reduces corrosion etc etc...
Post #146974 19th Oct 2012 12:18pm
i saw that as well and if you can flush the system properly then its a good option..
i liked the bit where Ed China took the pressure cap off when the engine was hot... ... - .- -.
Post #147000 19th Oct 2012 2:08pm
Simes
Just wondered if anyone else has tried it - looking at the costs, it won't be a lot more than the cost of the proper anti-freeze for these cars - and that needs changing regularly.
Post #147001 19th Oct 2012 2:19pm
When I was at Car Fest North in September they had a huge stand about this, I didn't understand at the time what it was about. Looked a faff to flush everything properly though. If your coolant has the right corrosion inhibitors it shouldn't be a problem though, especially in the UK.
In the Nordics or Africa/Australia, maybe its worth it? Discovery 4 HSE
Post #147006 19th Oct 2012 3:03pm
Even engines run on the right stuff for 20years will have deposits in the system as the only way around it is using pure water, ie de-ionized type stuff normally for irons as its got little impurities left in it to react with.
I can see the sound basis for this and the pressure reduction in the system is a good thing.
not far off 18litres is in a TD6 system though so that could be fun and ££ to change out! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147014 19th Oct 2012 3:39pm
£65 for 5 litres!!
Prep fluid is £40 for 5 litres...
So lets say £200 all in for a TD6 and then another £120 for enough prep fluid to clear the system out... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147015 19th Oct 2012 3:43pm
Simes
The prep fluid is (apparently) re-useable as long as you filter it. So you could do all the cars in the street...
Post #147023 19th Oct 2012 4:04pm
klf400
this stuff sounds to good to be true , however i wont condemn it untill further research is done , if it was proven then i guess i would give it a go 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #147086 19th Oct 2012 7:46pm
ahebron
New Zealand
Caterpillar have a similar product for all their engines. Might be a cheaper way of doing it or check out other large motor manufacturers to see what they use.
Adrian VW Amarok 2014 Highline auto
Post #148160 25th Oct 2012 11:32pm
fisha
Is there not a balance though regarding pressure. I thought the idea of running a pressured system was that it helped to push the coolant against the sides of the engine to get a better contact and thus better thermal energy transfer? V8 or else ...
Post #148173 26th Oct 2012 6:59am
Possibly, but the main benefit of running under pressure is to increase the temp at which the water boils Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148220 26th Oct 2012 10:14am
PDB
There is a similar discussion on another forum and one of the members found the follow:
97%+ removal of all previous coolant is mandatory in order to prevent corrosion.
Inhibitor deposition occurs on aluminum surfaces, which could cause issues in some radiators.
Engines run 115-140oF hotter (at the cylinder heads) with Evans products so Engine octane requirement is increased by 5-7 numbers.
Stabilized coolant temps are increased by 31-48oF, versus straight water with No-Rosion.
Reprogramming fan temp settings is mandatory to prevent the fan from running continuously.
Specific heat capacity (heat transfer ability) of Evans waterless products ranges from 0.64 to 0.68, or about half that of water.
Computerized ignition must retard engine timing by 8-10o to prevent trace knock.
Engine horsepower is reduced by 4-5%.
Accelerated recession of non-hardened valve seats in older engines is possible, due to brinelling.
Viscosity is 3-4 times higher than what OEM water pumps are rated to accommodate.
Coolant flow rate through radiator tubes is reduced by 20-25% due to the higher viscosity.
Race tracks prohibit Evans products because they are flammable and slippery when spilled.
I can't vouch for the accuracy and obviously some of the points won't be applicable here, but there are some points worth considering if true.
Paul
Post #149723 4th Nov 2012 6:11pm
mjdronfield
Shocked That never get mentioned on Wheeler Dealers.................
Obviously a bit more investigation is needed before you pay £320 odd is ? it all in, to change........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #149748 4th Nov 2012 8:48pm
