![]() | Home > Maintenance & Mods (L322) > Water free coolant |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Saw this stuff on Wheeler Dealers the other evening...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i saw that as well and if you can flush the system properly then its a good option..
Just wondered if anyone else has tried it - looking at the costs, it won't be a lot more than the cost of the proper anti-freeze for these cars - and that needs changing regularly. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
When I was at Car Fest North in September they had a huge stand about this, I didn't understand at the time what it was about. Looked a faff to flush everything properly though. If your coolant has the right corrosion inhibitors it shouldn't be a problem though, especially in the UK.
Even engines run on the right stuff for 20years will have deposits in the system as the only way around it is using pure water, ie de-ionized type stuff normally for irons as its got little impurities left in it to react with.
£65 for 5 litres!!
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Caterpillar have a similar product for all their engines. Might be a cheaper way of doing it or check out other large motor manufacturers to see what they use.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561 ![]() ![]() |
Is there not a balance though regarding pressure. I thought the idea of running a pressured system was that it helped to push the coolant against the sides of the engine to get a better contact and thus better thermal energy transfer? V8 or else ... |
Possibly, but the main benefit of running under pressure is to increase the temp at which the water boils |
PDB Member Since: 04 Oct 2012 Location: Lutterworth Posts: 15 ![]() ![]() |
There is a similar discussion on another forum and one of the members found the follow:
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
