Home > Maintenance & Mods (L322) > Fast idle after split expansion tank |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Hi Terry,
16th Oct 2012 9:11pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I wouldn't worry about it for the time being. Run the car and see if the ECU's adjust. You might need to take you car back to the LPG installer after 1000miles for a tune. I know my system was in a learning mode for 1000miles. After that the LPG map was adjusted and set to normal running. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Oct 2012 9:30pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1254 |
Engine should idle at 700rpm with air con on and drop down to 600rpm if the aircon is switched off.
17th Oct 2012 4:37pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
I would suggest you change the engine temp sensor, it may well be faulty after you lost the coolant when the expasion tank burst.
18th Oct 2012 10:11pm |
How bizar.........afte faffing around wih various codes yesterday (don't ask), Today my 4.4 decided to tick over at about 900rpm on both lpg and petrol so after 40 miles of trying to sort it out I reset all the defect codes by following this link
22nd Oct 2012 7:05pm |
