Home > Technical (L322) > 12v switched feed?
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
12v switched feed?
I bought a digital tv upgrade from lovemyauto, now I need to find a 12v ignition feed in the rear left boot; for it and i'm struggling to find one, could someone help me out? 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #147664 23rd Oct 2012 4:29pm
The ones that feed the bluetooth module or the current TV box should do as they will not be ignition switched but will only recieve power when the system is powered on Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147666 23rd Oct 2012 4:33pm
twhincup
Embarassed forgive my ignorance, but how do i identify the bluetooth module? and would any of the constant 12v feeds do? 2007 3.0L Diesel VW Touareg SE
Post #147667 23rd Oct 2012 4:39pm
Fuse 5 in the boot is ignition controlled and is unused.
Numbering starts from the left.
Post #147670 23rd Oct 2012 5:08pm
twhincup
thanks guys, i'm assuming ill need an ignition feed otherwise it would drain the battery.
I'll let you know how i get on 2007 3.0L Diesel VW Touareg SE
Post #147708 23rd Oct 2012 9:21pm
Budgie
This thread may be of assistance: http://www.fullfatrr.com/forum/topic12511....digital+tv
Post #147722 23rd Oct 2012 10:38pm
twhincup
thanks Budgie, much appreciated. The battery died so havent done it yet as only just fitted a new one but want to try and sort it out at the weekend Smile 2007 3.0L Diesel VW Touareg SE
Post #149202 31st Oct 2012 10:17pm
twhincup
a bit late, but a new battery fitted and i put a terminal on to an existing 12v feed and now up and running with TV. not without working out i need to power the aerial as well and place the aerial outside in the bumper as it doesnt work too well with tinted glass. 2007 3.0L Diesel VW Touareg SE
Post #165196 16th Jan 2013 6:48pm
They are all live aren't they nicey ?
Anyway see here:
http://www.fullfatrr.com/forum/post96346.html#96346
You want the purple wire for ignition live! .
Post #165312 17th Jan 2013 12:05am
You are indeed correct Joe, no ignition controlled fuses in the rear of the car even though the wiring diagram clearly indicates there are.
Purple wire as you indicate and also a green/yellow wire adjacent to the rear fuseboard which runs to serve the tow socket. Thumbs Up
Post #165353 17th Jan 2013 10:06am
Baris
There is no connection you can use from the TV tuner to power your digital tuner.
That's why everything is done and ready with my digital conversion, so no wires need to be cut or hunted down, and also a longer remote wire, so you can have it up front.
For the time being, you can use pin 16 from the bm54, which is 12v ignition. You don't want a live, as it will drain your battery.
Post #168563 29th Jan 2013 9:34pm
twhincup
ty Baris, do you have a link to your digital conversion? 2007 3.0L Diesel VW Touareg SE
Post #168923 30th Jan 2013 9:42pm
Baris
Not sure what you mean a link? You mean a review of it?
Post #169933 4th Feb 2013 11:40am
twhincup
yes, sorry i wasn't sure what you meant by your conversion as i haven't seen it Sad 2007 3.0L Diesel VW Touareg SE
Post #170053 4th Feb 2013 6:59pm
