![]() | Home > Technical (L322) > 12v switched feed? |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 ![]() ![]() |
I bought a digital tv upgrade from lovemyauto, now I need to find a 12v ignition feed in the rear left boot; for it and i'm struggling to find one, could someone help me out? 2007 3.0L Diesel VW Touareg SE
The ones that feed the bluetooth module or the current TV box should do as they will not be ignition switched but will only recieve power when the system is powered on |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Fuse 5 in the boot is ignition controlled and is unused.
thanks guys, i'm assuming ill need an ignition feed otherwise it would drain the battery.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
This thread may be of assistance: http://www.fullfatrr.com/forum/topic12511....digital+tv |
thanks Budgie, much appreciated. The battery died so havent done it yet as only just fitted a new one but want to try and sort it out at the weekend |
a bit late, but a new battery fitted and i put a terminal on to an existing 12v feed and now up and running with TV. not without working out i need to power the aerial as well and place the aerial outside in the bumper as it doesnt work too well with tinted glass. 2007 3.0L Diesel VW Touareg SE
They are all live aren't they nicey ? Anyway see here: http://www.fullfatrr.com/forum/post96346.html#96346 You want the purple wire for ignition live! . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
There is no connection you can use from the TV tuner to power your digital tuner.
ty Baris, do you have a link to your digital conversion? 2007 3.0L Diesel VW Touareg SE
Not sure what you mean a link? You mean a review of it? |
yes, sorry i wasn't sure what you meant by your conversion as i haven't seen it |
