![]() | Home > Maintenance & Mods (L322) > [SOLVED] "Wobbly" knocking at rear? |
Had this for a few weeks now. Happens at very low speed going over uneven bumps in the road, but also at other speeds. The front wheels or the rear wheels can set it off.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
just wondering if it could be the air suspension struts moving laterally..i've had this a few times but not really taken any notice of it.. ... - .- -.
Wheel bearing |
Time to get it up on some axle stands and have a good wiggle about |
If it is the wheel bearing it will be easily noticeable when you have the car lifted |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Im at work at the mo but seem to recal the bolt is roughly 10 inches long |
Hey, mercs600
I haven't a picture but yes that sounds like the one.
Checked the rear over the weekend. It is not the wheel bearings, nor the damper mounting (although I did get half a turn on it!) For reference the nut and bolt took a 13/16 or 21mm socket, same as a normal spark plug socket. Had a good wiggly and bash with leather mallet but nothing appears loose. MOT guy did indicate bottom hub bush had some slight movement 6 months ago (have all the new bushes to fit - just can't find the time to do it).
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
I don't suppose it could be anything to do with your exhaust moving around on its mountings could it? No longer FF owner but still interested. Present car Jaguar XE
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
hi joe
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1527 ![]() ![]() |
another major is the rear subframe/body mount bushes, they are whoppers and do go over time. ]
Hard to believe this one, but fixed my wobbly knocking at the rear.
