![]() | Home > Technical (L322) > Vehicle articulation error |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Now before you say it (use the search) this is not a normal EAS question.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I've had that error before when mine was in fault with "not enough energy to regulate front axel error". I thought it was |
so just been out in the car for a short drive and the suspension is at almost full height but with air suspension inactive on the dash.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Worn compressor so there four taking longer to lift and throwing an error onto no6 Range Rover
+1 and if it has 4 new height sensors it will be really screwed up. Have a read on my overhaul compressor post then get it hooked up to the RAC for a calibration. Think that will sort it. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks guys for the feedback - Rob, just tried to find your thread with no luck, do you have a link handy?
http://www.fullfatrr.com/forum/topic11310....sor+grease |
I would make sure it is not an airbag. Up to off road height and lift each corner manually listening for hissing. .
Possible air bag but would have thaught ecu would log overheat on compressor but worth checking onto no6 Range Rover
Replaced the compressor and now the car goes up and down nice and quickly - however... (there is always one isn't there).... when I run the RSW All comms on read faults on the EAS I am getting 'exhaust valve fault'.
Spoke way too soon....
