Home > In Car Electronics (L322) > New to FFRR- Phone/Bluetooth questions.
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hello,
Just bought a 2004 4.4v8 vogue. I am new to the FFRR forum. A couple of questions, does it have a built in telephone? I have seen the little telephone button on the sat nav screen? if it does how does it work? Also can I connect to the RR with bluetooth or do i have to make some modifications?
Also
When I start the RR after about twenty seconds it bleeps once very loud, this sounds like a telephone or bluetooth bleep! Any ideas.
thank you oli
Post #148433 27th Oct 2012 7:24am
daveo
yor car has to have the phone kit to work, do you have any signs of the phone cradle in your centre consol, the phone unit will be in the boot on the lefthand side,if you push and hold the telephone button on the wheel do you get a beep after a few seconds Question
the beeps you get after starting sounds like the confirmation beeps of a tracker.. V8 facelift Range Rover Autobiography 22" wheels.
Post #148436 27th Oct 2012 9:29am
mjdronfield
Bluetooth was never fitted to the early Range Rover as standard. If you don't have a phone in the centre cubby box, you will have to go the BMW ULF route if you want to keep it "standard" and use the buttons on the steering wheel etc........
Plenty of threads on the forum, do a search for BMW ULf or BMW Bluetooth........
http://www.fullfatrr.com/forum/topic14122.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #148438 27th Oct 2012 10:01am
oliver9627
So is there any way i can connect an i pod to the range rover in order for it to play music through the range rovers speakers?
or how easy is it to install a bluetooth system so that i can play it that way? COSTS??
Post #148513 27th Oct 2012 5:34pm
Have a look for intravee on the site...
Available for sale at http://www.toysinyourcar.com/acatalog/Range_Rover.html
I think your beep on startup maybe an aftermarket bluetooth kit? Have you tried searching for devices with your phone whilst your car is running?
Craig Thumbs Up
Post #148521 27th Oct 2012 5:51pm
daveo
theres a chap on here that will update your tuner to take bluetooth and will alow you to streem music, if thats what your looking for, the ulf module is not hard to fit but you need to have thepre wired phone kit in the car V8 facelift Range Rover Autobiography 22" wheels.
Post #148522 27th Oct 2012 5:51pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
You can update Bluetooth module to allow Bluetooth streaming?
Is this true? I thought it just allowed phone book to sync and it work with iPhone.
Post #148557 27th Oct 2012 9:09pm
daveo
no,,,the radio tuner, he can even put a pair of rca inputs into the unit, V8 facelift Range Rover Autobiography 22" wheels.
Post #148570 27th Oct 2012 10:42pm
ollielloyd
So how is this done? Is tuner in head unit or in boot? Cost?
Post #148572 27th Oct 2012 11:01pm
mjdronfield
Hi mate
The tuner is in the boot with all the other gubbins....
A member called baris can do the mod. He can also offer digital tv and an upgrade to the sound quality, each with their own cost.
If you search for bm54 amp upgrade you should find more info.
You can then make a choice as to your preferred route...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #148583 28th Oct 2012 8:25am
