Home > Technical (L322) > Xenon vs Bi-Xenon
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Xenon vs Bi-Xenon
Whille searching eBay I noticed the 2005+ headlights are different.
Some have one power pack and some have two.
Is this because some are Bi-Xenon?
What's the difference between the two? Other than presumably two Xenons? TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #14873 15th Mar 2010 12:05pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I thought bi meant high and low beam?
Single xenon was low/ dipped only 15MY SDV8 Vogue SE
Post #14885 15th Mar 2010 3:01pm
dan_uk_1984
Vogue was standard bi-Xenon with HSE being optional. When you switch from Main to Dipped you can sometimes see the flap move in the light (on the shaddow on the road).
There is also a standard type bulb that is used for flashing & in conjunction with the others as xenon's take a while to warm up and give 100% brightness.
Info from WSM
The Bi-xenon headlamps use a complex surface reflector for the halogen fill in main beam only lighting unit, as used on the halogen headlamp. This type of reflector is divided into separate parabolic segments, with each segment having a different focal length. The main beam bulbs are quartz halogen, with a rating of 55W. The bulbs are retained in the headlamp unit with conventional wire retaining clips. The bi-xenon headlamps operate as a dip beam and a main beam headlamp unit. The xenon lamp comprises a projector lens with a solenoid controlled shutter to change the beam output from dip to main beam.
They have a different design so you can see from up close if they are poverty spec:
Halogen:
Bi-Xenon:
Post #14888 15th Mar 2010 4:50pm
Macdaddy
Thanks fellas,
That's a more detailed reply than I was expecting thanks Dan!
Looks like I'll be wanting bi-xenon then. TDV8 HST Sport **Current**
Post #14905 15th Mar 2010 8:44pm
daveo
Funny as i was looking at my lights today, on the 06/07 lights, in the same unit as the side light there looks like another bulb chromed top, any ideas
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #14909 15th Mar 2010 10:16pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
That's the place where the optional cornering light goes.
Post #14915 16th Mar 2010 6:51am
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Yep, a halogen bulb that switches on when the steering wheel is turned - illuminates the sides of the car. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #14942 16th Mar 2010 6:32pm
adara
And here's a picture of the bulb:
Post #14943 16th Mar 2010 7:06pm
daveo
has any one got it, i havnt on my one V8 facelift Range Rover Autobiography 22" wheels.
Post #14948 16th Mar 2010 8:50pm
Yep ........ Thumbs Up
Post #14952 16th Mar 2010 8:58pm
jayzee
2005 onwards have it. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #14958 16th Mar 2010 9:28pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Really useful little extra. Especially off the beaten track with no street lights.
Post #15011 17th Mar 2010 7:52pm
My Vogue SE has the adaptive lights, really useful when pulling into our gateway at night, love the way it fades away after the turn.
Also, on a foggy night on full beam you really see how much the headlamps swivel with even the slightest steering adjustment. Discovery 4 HSE
1993 90 Tdi
Post #15027 17th Mar 2010 10:50pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
WARNING - REF Adaptive / Corning Lights
Was told recently by fellow FFRR owner (56 plate) - During recent blizzards, he was waiting approx. 10mins to pull out of junction in gridlocked traffic with his steering turned slightly to the left - He noticed small amount of smoke/steam just in front of bonnet - presummed it was from exhaust of car in front.
Unfortunatly turned out it was the inside of his headlight lens melting from the heat caused by this cornering bulb being on for so long - car was not covered by warranty because of its age and therefore LandRover didn't want to know .
Post #15185 20th Mar 2010 12:31am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I have the chromey-style extra bulb (2006 Vogue) but testing it when stationary (headlights on auto, indicator on, wheel turned) it doesn't light up.
Am I trying something wrongly or maybe the bulb has just blown?
Post #90841 7th Nov 2011 5:39pm
