Home > Technical (L322) > Suspension 'locked' in extended mode
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
car decided to raise itself into extended mode and now can't be lowered. the display has two front sensors in red below the image of the wheel & evey toime try to activate the suspension knob error massage on the dash stated SUSPENSION FAULT
Is thare any way of releasing the pressure or lowering ?
thanks in advance
Post #149076 31st Oct 2012 2:11pm
A dealership would be the best way as its still under warranty and you may be able to call LRA out to fix it with their test books. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149088 31st Oct 2012 3:18pm
duka
unfortunately it's not under warranty as its 2006 car
Post #149107 31st Oct 2012 4:26pm
Ahh just confused me as the profile you have has a 2010 on it Smile
best thing then maybe is a local Diag place or some kind member with EAS module or IID and seeing if another VIN could be added for a small charge Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149109 31st Oct 2012 4:30pm
try battery dis/re-connection, it might reset the ecu.. ... - .- -.
Post #149113 31st Oct 2012 4:33pm
You have got all the doors shut when you try to change the height?
Post #149135 31st Oct 2012 5:29pm
and another thought, you havnt pressed the 'lock' button accidentally.. ... - .- -.
Post #149136 31st Oct 2012 5:30pm
IIRC for the 2006 systems you cant lock in extended mode Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149139 31st Oct 2012 5:33pm
duka
I think it's an ECU / sensor or compressor problem.
It's not in accidental lock, it just raised itself and want go down - when try to lower orange light goes off and suspension fault error. Will try some diagnostics.
The 2010 car is my wife's bus!
Post #149179 31st Oct 2012 8:04pm
I think that's the biggest issue that needs sorting first!!
Seriously if the battery method doesn't wor then a diagnostic will be needed. Also check the sensors maybe give then a light wash and spray on some lithium grease Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149181 31st Oct 2012 8:06pm
duka
looks like a pressure releif valve is not venting when command is sent & front o/s sensor is intermittent, there didn't seem to be anything on wiki on checking/changing - anyone have any guidance on do's/dont's before I get in about at the weekend?
thanks in advance
Post #149434 2nd Nov 2012 10:16am
Lighty
Where in the country are you mate? 2 reasons for that question, 1 is in case you need any help have All-Comms diag here so may get different results you never know, also if you are in a particularly cold area I just wondered did this happen on a nice cold frosty morning recently and also was it raising from standard or access?
The pressure switch (ANR3902) is know to occasionaly stick, producing a false diagnosis of "inlet solenoid valve sticking" Landrover themselves never figured this out for years as there was never any stored fault in the ECU and suspension diagnosis would come back fine, so what did they do they advised new compressors which cured it for a while until it happened again and then they put out a recall on pressure switch only to find out later it was as I said above. Anyway the actual work around once youve sorted it is to have the ECU software updated which allows faultless working at lower tempreatures.
Cheers
Paul
PS Pressutr switch are about 25 nicker if I remember
Post #149521 2nd Nov 2012 7:41pm
